50
When I followed the community docks I came across the following issue:
 sudo add-apt-repository \
>    "deb [arch=amd64] https://download.docker.com/linux/ubuntu \
>    $(lsb_release -cs) \
>    stable"
[sudo] password for yogesh:
Hit:1 https://download.docker.com/linux/ubuntu bionic InRelease
Get:2 http://in.archive.ubuntu.com/ubuntu focal InRelease [265 kB]
Ign:3 http://dl.google.com/linux/chrome/deb stable InRelease
Ign:4 https://download.docker.com/linux/ubuntu focal InRelease
Hit:5 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:6 http://packages.microsoft.com/repos/vscode stable InRelease
Err:7 https://download.docker.com/linux/ubuntu focal Release
  404  Not Found [IP: 54.182.0.11 443]
Hit:8 http://dl.google.com/linux/chrome/deb stable Release
Hit:10 http://in.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:11 http://in.archive.ubuntu.com/ubuntu focal-backports InRelease
Reading package lists... Done
E: The repository 'https://download.docker.com/linux/ubuntu focal Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Yogesh Jog
  • 1,889
Update: As of 3 AM on May 15, the official Docker repository is available for Ubuntu Focal, so you can follow the installation guide on your Ubuntu to get Docker up and running.
Another option is to install Ubuntu-provided version of Docker:
sudo apt install docker.io
Long ago there were significant backlashes against this because the package docker.io from upstream (Debian) was too old - this is no longer the case. For Focal, docker.io is currently (Apr 24, 2020) at 19.03.8-0ubuntu1, which is satisfactorily new for the majority of Docker workloads.
Don't install docker by mistake - it used to be the system tray application, which has since been replaced by gnome-shell-extension-ubuntu-dock. The docker package can be safely removed had you installed it accidentally.
iBug
  • 1,859
49
Release file is available now. Follow the docker community guidelines.
As of today 28, April the release file for Ubuntu 20.04 LTS focal is not available.
So in order to install docker on Ubuntu 20.04 LTS focal release as guided on docker community link
you can change the following command :
$ sudo add-apt-repository \
   stable"
to
   bionic \
   stable"
By that what we are doing is we are using bionic (Ubuntu 18.04 LTS) release file.
Rest of the commands are okay and will work on 20.04 as well.
Also make sure that you removed the following entry from your /etc/apt/sources.list if present before installing docker
deb [arch=amd64] https://download.docker.com/linux/ubuntu focal stable
Yogesh Jog
  • 1,889
You can install it using a single command
sudo apt install docker-compose
Atif
  • 594
Following steps can help you:
Run the following commands:
sudo apt-get update
sudo apt-get install \
    apt-transport-https \
    ca-certificates \
    curl \
    gnupg-agent \
    software-properties-common
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
Open /etc/apt/sources.list file by running
sudo nano /etc/apt/sources.list
Comment out the following line:
#deb [arch=amd64] https://download.docker.com/linux/ubuntu focal stable
Press Ctrl+o to save, ctrl+x to close.
enter image description here Run the following command to install docker:
sudo apt update && sudo apt install docker-ce docker-ce-cli containerd.io
Running the above command will successfully install docker:
You can verify the docker version to confirm if it has been installed successfully:
docker -v
EDIT:
If you are on AWS EC2 just run the following command and it will install the Docker there:
sudo systemctl enable --now docker
Raghav
  • 783
