13
I am trying to setup a development machine using 20.04 and am having problems with the Monodevelop environment.
Whenever I create a solution and project it seems that it cannot find the proper build setup. I suspect there is some problem when using the 18.04 mono repositories on 20.04, but I can't find out how to fix it.
This is the error I receive when I try to build using the Monodevelop IDE:
/usr/lib/mono/msbuild/15.0/bin/Microsoft.CSharp.CurrentVersion.targets(5,5):
Error MSB4019: The imported project "/usr/lib/mono/msbuild/15.0/bin/Roslyn/Microsoft.CSharp.Core.targets" was not found.
Confirm that the path in the <Import> declaration is correct, and that the file exists on disk. (MSB4019) (HelloWorld)
Does anyone know how to get a working version of Monodevelop on Ubuntu 20.04?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
sysrpl
  • 261
I managed to fix this on Ubuntu 20.04.
First, add mono-project's repo for 18.04 by following the official instructions, pasted here for convenience:
sudo apt install gnupg ca-certificates
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
echo "deb https://download.mono-project.com/repo/ubuntu stable-bionic main" | sudo tee /etc/apt/sources.list.d/mono-official-stable.list
sudo apt update
Then install mono-roslyn using:
sudo apt install mono-roslyn
Rebuild your project.
vydd
  • 81
Mono is not yet available in stable repo, but you can install it with the preview-focal main with the following.
echo "deb https://download.mono-project.com/repo/ubuntu preview-focal main" | sudo tee /etc/apt/sources.list.d/mono-official-preview.list
sudo apt update
# if the packages were already installed
sudo apt upgrade
# otherwise
sudo apt install mono-complete msbuild
Later you can test it with a simple hello world application by creating a file called hello.cs
using System;
public class HelloWorld
    public static void Main(string[] args)
        Console.WriteLine ("Hello Mono World");
Compile it with csc hello.cs. It will generate an exe. Now run it with mono hello.exe and it should work
diegosasw
  • 241
I try but get Debugger operation failed
ApplicationName='/usr/lib/gnome-terminal/gnome-terminal-
server', CommandLine='--app-id
mono.develop.id9462e6d67d3f4540ace204fe87960524',
CurrentDirectory='', Native error= Cannot find the specified file
Kulfy
  • 18,154
I've had luck with setting up monodevelop 7.8.4 (build 2) Mono version 6.12.0.122 on Ubuntu 21.10 using Debian Buster source.
  1. First you will need to install libjpeg62-turbo_1.5.2-2+deb10u1_amd64.deb.
  2. Once you have this installed, open a terminal and type:
    echo "deb https://download.mono-project.com/repo/debian buster main" | sudo tee /etc/apt/sources.list.d/mono-official-vs.list
    sudo apt update
    sudo apt install monodevelop
  3. At this point monodevelop loads and runs, but will not debug and you will see an error that looks like this:
    ApplicationName='/usr/lib/gnome-terminal/gnome-terminal-server', CommandLine='--app-id mono.develop.id9462e6d67d3f4540ace204fe87960524', CurrentDirectory='', Native error= Cannot find the specified file
  4. To fix this, we go back to the terminal and run:
    cd /usr/lib
    sudo mkdir gnome-terminal
    cd gnome-terminal
    sudo ln -s /usr/libexec/gnome-terminal-server
  5. Reboot and enjoy.
