19
Raised bug -> https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1874257
SSH timeout issue, once connect to VPN.
Connecting via putty fine. No changes made before.
VPN established by open-connect. This is previously working. Reinstalled VPN packages and reboot still no luck
Environment
Dell XPS 9570
Ubuntu 16.04.6 Xenial Xerus)
kernel - 4.15.0-55-generic
$dpkg -l | grep -i openssh
ii openssh-client 1:7.2p2-4ubuntu2.8 -->
ii openssh-server 1:7.2p2-4ubuntu2.8
ii openssh-sftp-server 1:7.2p2-4ubuntu2.8
VPN tunnel info
vpn0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          inet addr:IP P-t-P:xx Mask:255.255.252.0
          inet6 addr: fe80::b8e2:bea4:2e62:fe08/64 Scope:Link
          UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1406 Metric:1
          RX packets:962 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1029 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:500
          RX bytes:87839 (87.8 KB) TX bytes:238740 (238.7 KB)
Issue
Unable to connect to any host via ssh or sftp after VPN connection
Tried
Reinstalled the openssh-client package and still no luck. May I know why the default cipher is not taking/hanging? Please let me know . There were no recent changes.
Workaround
Able to connect to ssh / sftp $ssh -c aes128-ctr user@IP
Below is the debug ssh client logs ===
$ssh -vvv user@ip
OpenSSH_7.2p2 Ubuntu-4ubuntu2.8, OpenSSL 1.0.2g 1 Mar 2016
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: resolving "IP" port 22
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to IP [IP] port 22.
debug1: Connection established.
debug1: key_load_public: No such file or directory
debug1: identity file /home/user/.ssh/id_rsa type -1
debug1: identity file /home/user/.ssh/id_rsa-cert type -1
debug2: compression stoc: none,zlib@openssh.com
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256@libssh.org
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug3: send packet: type 30
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
<< Hangs here >>
Please shed some views
Thanks
Jay
  • 331
6 Answers6
12
As a temporary workaround, setting the KEX algorithm manually solves this problem for me.
Add KexAlgorithms ecdh-sha2-nistp521 to the corresponding SSH config, or add -oKexAlgorithms=ecdh-sha2-nistp521 to the command line args for one time use.
Reference (2019): https://superuser.com/a/1462220/555702
bfrguci
  • 674
11
Setting MTU to 1200 solved it for me (Ubuntu 20.04).
with (replace {dev}):
sudo ip li set mtu 1200 dev {dev}
lesinto
  • 111
The root cause of the issue is with the openconnect VPN client package, MTU handling fail to negotiate. Bug -> https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1874257
Jay
  • 331
A colleague of mine just experienced this hanging at "expecting SSH2_MSG_KEX_ECDH_REPLY" issue this morning. He couldn't ssh into an Ubuntu 20.04.2 LTS server via OpenVPN. At first I thought it was an MTU issue but it turns out that it was a file permissions issue. Our organization uses signed keys and the file containing the CA public key only had owner read/write permissions.
We fixed the problem by adding read permissions for all users:
chmod a+r ca.pub
The bizarre thing about this problem was that even with the highest level of debug enabled while trying to use the ssh client, there was no error reported relating to the inability to read the file. The only related debug message had to do with successfully finding the @cert-authority line in the known_hosts file.
I've experienced the problem while trying to connect to a GCP Ubuntu 22 VM which is a part of a ZeroTier network. A ZeroTier interface zt<xxxx> defaults MTU to 2800. Setting it to 1300 solved the issue.
BMC
  • 201
Most of the time it happens because of PMTUD (Path MTU Discovery) does not work between client host and server host. Usually because (some) ICMP traffic is blocked on the path. Reasons might be:
  • hardened security
  • sometimes administrators being unaware of PMTUD use firewall rules without taking into account that the routers on the path can also participate in the connection, namely send ICMP messages
  • probably bugs in the software, for example I noticed that PMTUD stop working on MikroTik when you changing routing table in mangle table (though this could be expected behaviour)
Whatever the reason, the ICMP "unreachable" message is not sent to one or both participating hosts.
Changing MTU on the one or the both sides will work, but in most cases it is not desired and only can be recommended as a temporary workaround.
Instead, I recommend fixing PMTUD if possible. For example you have hosts A and B, routers R1 and R2 connected via the tunnel:
A ---- R1 ===== R2 ---- B
Tunnels usually has smaller MTU than standard 1500 LAN MTU.
  • If it is broken by some complex firewall setup on the routers, there could be a way to specify the rule that allows outgoing traffic from the router to the participating hosts
  • The other way is to use the workaround called MSS clamping. It can be done using rules in mangle table. Linux example: iptables -t mangle -A FORWARD -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu. You can do this on any other capable router like Cisco, MikroTik, etc. It is better than reducing your MTU and therefore the network performance. Note that if there are some other routers between R1 and R2 which has lower MTU then R1 or R2 can not know which MSS to set. In this case you should set MSS explicitly like this iptables -t mangle -A POSTROUTING -p tcp --tcp-flags SYN,RST SYN -o wireguard0 -j TCPMSS --set-mss 1380. Check here
Sometimes setting up MSS clamping for outgoing traffic is enough. Sometimes you need to set it up for both traffic coming from the tunnel and for traffic going to the tunnel.
Alek_A
  • 690
