I'm trying to follow https://www.tensorflow.org/install/gpu#ubuntu_1804_cuda_101 to get docker working with GPU on Ubuntu 18.04.4 LTS.
I'll copy the instructions here for reference:
# Add NVIDIA package repositories
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/cuda-repo-ubuntu1804_10.1.243-1_amd64.deb
sudo apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/7fa2af80.pub
sudo dpkg -i cuda-repo-ubuntu1804_10.1.243-1_amd64.deb
sudo apt-get update
wget http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64/nvidia-machine-learning-repo-ubuntu1804_1.0.0-1_amd64.deb
sudo apt install ./nvidia-machine-learning-repo-ubuntu1804_1.0.0-1_amd64.deb
sudo apt-get update
# Install NVIDIA driver
sudo apt-get install --no-install-recommends nvidia-driver-430
# Reboot. Check that GPUs are visible using the command: nvidia-smi
# Install development and runtime libraries (~4GB)
sudo apt-get install --no-install-recommends \
    cuda-10-1 \
    libcudnn7=7.6.4.38-1+cuda10.1  \
    libcudnn7-dev=7.6.4.38-1+cuda10.1
# Install TensorRT. Requires that libcudnn7 is installed above.
sudo apt-get install -y --no-install-recommends libnvinfer6=6.0.1-1+cuda10.1 \
    libnvinfer-dev=6.0.1-1+cuda10.1 \
    libnvinfer-plugin6=6.0.1-1+cuda10.1
I made it halfway through the steps above and got an error:
$ sudo apt-get install --no-install-recommends nvidia-driver-430
Reading package lists... Done
Building dependency tree
 nvidia-driver-430 : Depends: libnvidia-gl-430 (= 430.50-0ubuntu0.18.04.2) but it is not going to be installed
                     Depends: nvidia-dkms-430 (= 430.50-0ubuntu0.18.04.2)
                     Depends: nvidia-kernel-source-430 (= 430.50-0ubuntu0.18.04.2) but it is not going to be installed
                     Depends: libnvidia-decode-430 (= 430.50-0ubuntu0.18.04.2) but it is not going to be installed
                     Depends: libnvidia-encode-430 (= 430.50-0ubuntu0.18.04.2) but it is not going to be installed
                     Depends: nvidia-utils-430 (= 430.50-0ubuntu0.18.04.2) but it is not going to be installed
                     Depends: xserver-xorg-video-nvidia-430 (= 430.50-0ubuntu0.18.04.2) but it is not going to be installed
                     Depends: libnvidia-cfg1-430 (= 430.50-0ubuntu0.18.04.2) but it is not going to be installed
                     Depends: libnvidia-ifr1-430 (= 430.50-0ubuntu0.18.04.2) but it is not going to be installed
I noticed that I already have an nvidia driver installed, but it is not version 430: what I have in my apt list --installed includes:
nvidia-384/bionic-updates,now 390.116-0ubuntu0.18.04.3 amd64 [installed,upgradable to: 418.87.01-0ubuntu1]
nvidia-384-dev/bionic-updates,now 390.116-0ubuntu0.18.04.3 amd64 [installed,upgradable to: 418.87.01-0ubuntu1]
nvidia-common/now 1:0.5.3~ppa3 amd64 [installed,local]
nvidia-compute-utils-390/bionic-updates,now 390.116-0ubuntu0.18.04.3 amd64 [installed]
nvidia-container-toolkit/bionic,now 1.0.5-1 amd64 [installed]
nvidia-dkms-390/bionic-updates,now 390.116-0ubuntu0.18.04.3 amd64 [installed]
nvidia-driver-390/bionic-updates,now 390.116-0ubuntu0.18.04.3 amd64 [installed]
nvidia-headless-390/bionic-updates,now 390.116-0ubuntu0.18.04.3 amd64 [installed]
nvidia-headless-no-dkms-390/bionic-updates,now 390.116-0ubuntu0.18.04.3 amd64 [installed]
nvidia-kernel-common-390/bionic-updates,now 390.116-0ubuntu0.18.04.3 amd64 [installed]
nvidia-kernel-source-390/bionic-updates,now 390.116-0ubuntu0.18.04.3 amd64 [installed]
nvidia-libopencl1-384/bionic-updates,now 390.116-0ubuntu0.18.04.3 amd64 [installed,upgradable to: 418.87.01-0ubuntu1]
nvidia-machine-learning-repo-ubuntu1804/unknown,now 1.0.0-1 amd64 [installed]
nvidia-opencl-icd-384/bionic-updates,now 390.116-0ubuntu0.18.04.3 amd64 [installed,upgradable to: 418.87.01-0ubuntu1]
nvidia-prime/now 0.8.9~ppa3 all [installed,local]
nvidia-settings/unknown,now 440.64.00-0ubuntu1 amd64 [installed]
nvidia-utils-390/bionic-updates,now 390.116-0ubuntu0.18.04.3 amd64 [installed]
Here is what does currently work:
  • I'm able to run nvidia-smi. It says I have Driver Version: 390.116
  • I have Docker version 19.03.8, build afacb8b7f0
  • My apt list --installed includes nvidia-container-toolkit/bionic,now 1.0.5-1 amd64 [installed], which I installed following some of the instructions at https://github.com/NVIDIA/nvidia-docker
  • My apt list --installed includes cuda-repo-ubuntu1804/unknown,now 10.2.89-1 amd64 [installed]
Here is what does not work:
$ sudo docker run --gpus all nvidia/cuda:10.0-base nvidia-smi
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused "process_linux.go:449: container init caused \"process_linux.go:432: running prestart hook 0 caused \\\"error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: requirement error: unsatisfied condition: cuda>=10.0, please update your driver to a newer version, or use an earlier cuda container\\\\n\\\"\"": unknown.
ERRO[0000] error waiting for container: context canceled
The error says I need cuda>=10.0, which is why I was trying to follow https://www.tensorflow.org/install/gpu#ubuntu_1804_cuda_101.
What should I do to get sudo docker run --gpus all nvidia/cuda:10.0-base nvidia-smi working?
Edit: I noticed that https://github.com/NVIDIA/nvidia-docker/wiki/Frequently-Asked-Questions#how-do-i-install-the-nvidia-driver says to install the cuda-drivers package. I got this error when attempting to install it:
$ sudo apt install cuda-drivers
 cuda-drivers : Depends: libnvidia-encode-440 (>= 440.64.00) but it is not going to be installed
                Depends: libnvidia-fbc1-440 (>= 440.64.00) but it is not going to be installed
                Depends: libnvidia-ifr1-440 (>= 440.64.00) but it is not going to be installed
                Depends: nvidia-compute-utils-440 (>= 440.64.00) but it is not going to be installed
                Depends: nvidia-dkms-440 (>= 440.64.00)
                Depends: nvidia-driver-440 (>= 440.64.00) but it is not going to be installed
                Depends: xserver-xorg-video-nvidia-440 (>= 440.64.00) but it is not going to be installed
Are my apt install errors (E: Unable to correct problems, you have held broken packages.) related to the sources I have in my /etc/apt config?
$ rg "cuda" /etc/apt/sources.list.d
/etc/apt/sources.list.d/cuda.list.save
1:deb http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64 /
$ rg "nvidia" /etc/apt/sources.list.d
/etc/apt/sources.list.d/nvidia-machine-learning.list
1:deb http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64 /
/etc/apt/sources.list.d/nvidia-docker.list.save
1:deb https://nvidia.github.io/libnvidia-container/ubuntu18.04/$(ARCH) /
2:deb https://nvidia.github.io/nvidia-container-runtime/ubuntu18.04/$(ARCH) /
3:deb https://nvidia.github.io/nvidia-docker/ubuntu18.04/$(ARCH) /
Adrian
  • 373
I was able to get sudo docker run --gpus all nvidia/cuda:10.0-base nvidia-smi working.
I had to first run
$ sudo apt-get install libnvidia-compute-430
The following packages will be REMOVED:
  libnvidia-compute-390 libnvidia-decode-390 libnvidia-encode-390 nvidia-384 nvidia-384-dev nvidia-compute-utils-390 nvidia-driver-390 nvidia-headless-390
  nvidia-headless-no-dkms-390 nvidia-libopencl1-384 nvidia-opencl-icd-384 nvidia-utils-390
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 12 to remove and 15 not upgraded.
Need to get 20.2 MB of archives.
After this operation, 13.0 MB of additional disk space will be used.
After that, I was able to run sudo apt-get install nvidia-driver-430 (the https://www.tensorflow.org/install/gpu#ubuntu_1804_cuda_101 step on which I was originally blocked).
My nvidia-smi now says NVIDIA-SMI 430.50 Driver Version: 430.50 CUDA Version: 10.1.
Adrian
  • 373
