I'm trying to use GParted to resize an ext4 partition on /dev/sda2, and I've been watching a youtube tutorial for that. But my /dev/sda2 cannot be resized. I've tried to change the number but it kept returning to the previous value. I've tried to use cursor but still cannot. when I saw on youtube it could reduce the partition size just shifting dev/sda2. I cannot shift the /dev/sda2 by the cursor and resize that.
Raffa
  • 34,963
mycode binary
  • 23
Make sure that you have a good backup of your important Ubuntu files, as this procedure can corrupt or lose data.
Keep these things in mind:
  • always start the entire procedure with issuing a swapoff on any mounted swap partitions, and end the entire procedure with issuing a swapon on that same swap partition
  • a move is done by pointing the mouse pointer at the center of a partition and dragging it left/right with the hand cursor
  • a resize is done by dragging the left/right side of a partition to the left/right with the directional arrow cursor
  • if any partition can't be moved/resized graphically, you may have to manually enter the specific required numeric data (don't do this unless I instruct you to)
  • you begin any move/resize by right-clicking on the partition in the lower pane of the main window, and selecting the desired action from the popup menu, then finishing that action in the new move/resize window
Do the following...
Note: if the procedure doesn't work exactly as I outline, STOP immediately and DO NOT continue.
Note: this assumes an ext4 partition for /dev/sda2, and that you wish to reduce the partition size.
  • boot to a Ubuntu Live DVD/USB, in “Try Ubuntu” mode
  • start gparted
  • resize the right side of /dev/sda2 to the left as far as desired
  • click the Apply icon
heynnema
  • 73,649
