I've enabled the root account by setting a password for it but not matter what I try I cant log into any DE but the default unity one, while any other user (but root) can choose any DE
Jorge Castro
  • 73,717
Atheer
You can't log in to the GUI as root as it is an astronomically bad thing to do. Log on as a normal user and use sudo <command> if you really require root privileges. I've been using various kinds of Unix and Linux for 20 years and never had to log on to the GUI as root.
jippie
  • 5,733
DO NOT LOG INTO GNOME AS ROOT
This is impossible to do because if it did allow you do to do that MANY things wouldn't work correctly.
Any reason you might have for wanting to do this stems from misunderstanding something.
For a discussion about why not to log in as root, see Why is it bad to login as root?
David Oneill
  • 12,614
https://unix.stackexchange.com/questions/284772/gnome-3-is-not-allowing-me-to-log-in-as-root
You should edit the file /etc/pam.d/gdm-password commenting the line that contains the root user check,
#auth required    pam_succeed_if.so user != root quiet_success
Scorpion
  • 384
  • 15
