Everything was working for months until on the day I ordered new keyboards and monitor I woke my Dell inspiron15 up and external HDMI monitor was not recognized anymore. Can't make this stuff up.
- Checked monitor with different PC - WORKS
- Checked my PC HDMI port - WORKS (monitor starts scanning procedure)
First off, I have tried everything here but I'm getting he following:
sudo xrandr --output HDMI-1 --auto <-- OK
sudo xrandr --addmode HDMI-1 1920x1080 <-- OK
sudo xrandr --output HDMI-1 --mode 1920x1080 --pos 0x0 <--ERR: xrandr: Configure crtc 1 failed
I also tried to replace the 3rd command with this but same ERR:
sudo xrandr --output HDMI-1 --mode 1920x1080 --right-of eDP-1
Here is my setup:
Graphics: Mesa IntelĀ® UHD Graphics 620 (KBL GT2)
Output of lshw -c video
*-display
description: VGA compatible controller
product: UHD Graphics 620
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 07
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:138 memory:d1000000-d1ffffff memory:b0000000-bfffffff ioport:f000(size=64) memory:c0000-dffff
*-display
description: Display controller
product: Topaz XT [Radeon R7 M260/M265 / M340/M360 / M440/M445]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:01:00.0
version: c1
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi bus_master cap_list rom
configuration: driver=amdgpu latency=0
resources: irq:140 memory:c0000000-cfffffff memory:d0000000-d01fffff ioport:e000(size=256) memory:d0200000-d023ffff memory:d0240000-d025ffff
Output of xrandr --verbose
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 60.01*+ 60.01 59.97 59.96 59.93 47.10
1680x1050 59.95 59.88
1600x1024 60.17
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1440x900 59.89
1400x900 59.96 59.88
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis) <-- ISSUE HERE???
1920x1080 60.01
Pulling hair and running out of ideas how to fix this. Any pointers much appreciated. Thanks!
Notes:
- I vaguely remember having this HDMI disconnect issues before but then the xrandr commands fixed it.
- Kindly note that I don't have nvidia graphics.
