-1
Tried to install python3-dev and libssl-dev on a new Ubuntu 18.04 with:
$ sudo apt install libssl-dev python3-dev
But i get the following Error:
Reading package lists... Done
Building dependency tree
libssl-dev : Depends: libssl1.1 (= 1.1.0g-2ubuntu4) but 1.1.1-1ubuntu2.1~18.04.4 is to be installed
              Recommends: libssl-doc but it is not going to be installed
python3-dev : Depends: python3 (= 3.6.5-3) but 3.6.7-1~18.04 is to be installed
              Depends: libpython3-dev (= 3.6.5-3) but it is not going to be installed
              Depends: python3.6-dev (>= 3.6.5-2~) but it is not going to be installed
What could cause this issue, and how to fix it?
Simon Sudler
  • 4,111
