On Ubuntu 18:04 Bionic (installed as a Singularity container) I issue
apt-get install okular
and I get the message "E: Unable to locate package okular".
Why? Is okular not in the apt repositories any more? How do I install it then?
A possible fix would be to use the following command to add the "universe" repository:
sudo add-apt-repository universe
Or, if this returns an error, try:
sudo add-apt-repository "deb http://archive.ubuntu.com/ubuntu $(lsb_release -sc) universe"
If none of these work, then inside the terminal, type:
sudo apt-get install software-properties-common
and repeat the first command.
Then finally update by typing:
sudo apt update
Then try installing again by:
sudo apt-get install okular
Hopefully this works out.
