unfortunately I experience the following error when running
$ gpg2 --refresh-keys
gpg: refreshing 18 keys from hkps://keys.openpgp.org
gpg: keyserver refresh failed: General error
As you can gather from the above, I've configured the keyserver to be hkps://keys.openpgp.org in ~/.gnupg/dirmngr.conf as suggested here. This is the full content of ~/.gnupg/dirmngr.conf:
keyserver hkps://keys.openpgp.org
verbose
debug 4096
debug-level 4096
debug-all
log-file /tmp/dirmngr.log
Running gpg2 --refresh-keys again after pkill dirmngr gives this in /tmp/dirmngr.log
2020-04-19 23:36:35 dirmngr[20588.0] listening on socket '/home/whoami/.gnupg/S.dirmngr'
2020-04-19 23:36:35 dirmngr[20589.0] can't access directory '/etc/gnupg2/trusted-certs': No such file or directory
2020-04-19 23:36:35 dirmngr[20589.0] can't access directory '/etc/gnupg2/extra-certs': No such file or directory
2020-04-19 23:36:35 dirmngr[20589.0] permanently loaded certificates: 0
2020-04-19 23:36:35 dirmngr[20589.0]     runtime cached certificates: 0
2020-04-19 23:36:36 dirmngr[20589.0] handler for fd 0 started
2020-04-19 23:36:36 dirmngr[20589.0] DBG: chan_0 -> # Home: /home/whoami/.gnupg
2020-04-19 23:36:36 dirmngr[20589.0] DBG: chan_0 -> # Config: /home/whoami/.gnupg/dirmngr.conf
2020-04-19 23:36:36 dirmngr[20589.0] DBG: chan_0 -> OK Dirmngr 2.1.11 at your service
2020-04-19 23:36:36 dirmngr[20589.0] connection from process 20586 (1000:1000)
2020-04-19 23:36:36 dirmngr[20589.0] DBG: chan_0 <- GETINFO version
2020-04-19 23:36:36 dirmngr[20589.0] DBG: chan_0 -> D 2.1.11
2020-04-19 23:36:36 dirmngr[20589.0] DBG: chan_0 <- KEYSERVER
2020-04-19 23:36:36 dirmngr[20589.0] DBG: chan_0 -> S KEYSERVER hkps://keys.openpgp.org
2020-04-19 23:36:36 dirmngr[20589.0] DBG: chan_0 <- KS_GET -- LIST_OF_KEYS
2020-04-19 23:36:36 dirmngr[20589.0] resolve_dns_addr for 'keys.openpgp.org': 'keys.openpgp.org' [already known]
2020-04-19 23:36:36 dirmngr[20589.0] TLS verification of peer failed: status=0x0042
2020-04-19 23:36:36 dirmngr[20589.0] TLS verification of peer failed: The certificate is NOT trusted. The certificate issuer is unknown.
2020-04-19 23:36:36 dirmngr[20589.0] DBG: expected hostname: keys.openpgp.org
2020-04-19 23:36:36 dirmngr[20589.0] DBG: BEGIN Certificate 'server[0]':
2020-04-19 23:36:36 dirmngr[20589.0] DBG:      serial: 031419524A880F1D74B7C7BF3514F95D3FFA
2020-04-19 23:36:36 dirmngr[20589.0] DBG:   notBefore: 2020-04-02 04:32:09
2020-04-19 23:36:36 dirmngr[20589.0] DBG:    notAfter: 2020-07-01 04:32:09
2020-04-19 23:36:36 dirmngr[20589.0] DBG:      issuer: CN=Let's Encrypt Authority X3,O=Let's Encrypt,C=US
2020-04-19 23:36:36 dirmngr[20589.0] DBG:     subject: CN=keys.openpgp.org
2020-04-19 23:36:36 dirmngr[20589.0] DBG:   hash algo: 1.2.840.113549.1.1.11
2020-04-19 23:36:36 dirmngr[20589.0] DBG:   SHA1 fingerprint: 447582CA4F0DDA406F88D52DBBDF35B16C060B7D
2020-04-19 23:36:36 dirmngr[20589.0] DBG: END Certificate
2020-04-19 23:36:36 dirmngr[20589.0] DBG: BEGIN Certificate 'server[1]':
2020-04-19 23:36:36 dirmngr[20589.0] DBG:      serial: 0A0141420000015385736A0B85ECA708
2020-04-19 23:36:36 dirmngr[20589.0] DBG:   notBefore: 2016-03-17 16:40:46
2020-04-19 23:36:36 dirmngr[20589.0] DBG:    notAfter: 2021-03-17 16:40:46
2020-04-19 23:36:36 dirmngr[20589.0] DBG:      issuer: CN=DST Root CA X3,O=Digital Signature Trust Co.
2020-04-19 23:36:36 dirmngr[20589.0] DBG:     subject: CN=Let's Encrypt Authority X3,O=Let's Encrypt,C=US
2020-04-19 23:36:36 dirmngr[20589.0] DBG:   SHA1 fingerprint: E6A3B45B062D509B3382282D196EFE97D5956CCB
2020-04-19 23:36:36 dirmngr[20589.0] TLS connection authentication failed: General error
2020-04-19 23:36:36 dirmngr[20589.0] error connecting to 'https://keys.openpgp.org:443': General error
What's the problem here?
  • Do I have to specify (TLS) certificates for gpg2 separately? If yes, how do I do so?
  • Or am I missing something in ~./gnupg/dirmngr.conf?
  • Or why else is the TLS connection failing?
Thanks in advance for your help!
EDIT 1
$ gpg2 --version | head -n 1
gpg (GnuPG) 2.1.11
EDIT 2
$ dirmngr --version | head -n 1
dirmngr (GnuPG) 2.1.11
After reading the log more thoroughly and checking the dirmngr manpage, I realized that on my system the whole /etc/gnupg directory is missing.
FILES
Dirmngr makes use of several directories when running in daemon mode:
~/.gnupg
/etc/gnupg The first is the standard home directory for all configuration files. In the deprecated system daemon mode the second direc‐ tory is used instead.
/etc/gnupg/trusted-certs This directory should be filled with certificates of Root CAs you are trusting in checking the CRLs and signing OCSP Reponses.
      Usually  these are the same certificates you use with the appli‐
      cations making use of dirmngr.  It  is  expected  that  each  of
      these certificate files contain exactly one DER encoded certifi‐
      cate in a file with the suffix ‘.crt’ or ‘.der’.  dirmngr  reads
      those certificates on startup and when given a SIGHUP.  Certifi‐
      cates which are not readable or do not make up  a  proper  X.509
      certificate are ignored; see the log file for details.
      Applications  using  dirmngr (e.g. gpgsm) can request these cer‐
      tificates to complete a trust chain in the same way as with  the
      extra-certs directory (see below).
      Note that for OCSP responses the certificate specified using the
      option --ocsp-signer is always considered  valid  to  sign  OCSP
      requests.
/etc/gnupg/extra-certs This directory may contain extra certificates which are pre‐ loaded into the interal cache on startup. Applications using dirmngr (e.g. gpgsm) can request cached certificates to complete a trust chain. This is convenient in cases you have a couple intermediate CA certificates or certificates ususally used to sign OCSP reponses. These certificates are first tried before going out to the net to look for them. These certificates must also be DER encoded and suffixed with ‘.crt’ or ‘.der’.
Since this might be of relevance, how can I create and fill /etc/gnupg with its default values? Or do I have to do it manually? And why is this directory missing in the first place?
apitsch
  • 342
For me the following fixed it:
$ echo "hkp-cacert /usr/share/gnupg/sks-keyservers.netCA.pem" >> ~/.gnupg/dirmngr.conf
The documentation says that if hkp-cacert isn't specified it uses the system certificate store for regular hostnames and the the bundled certificate for the default keyserver pool.
$ gpg --search-keys 0B7F8B60E3EDFAE3
gpg: error searching keyserver: General error
gpg: keyserver search failed: General error
$ systemctl --user stop dirmngr.service # or restart manually, this assumes socket activation $ gpg --search-keys 0B7F8B60E3EDFAE3 gpg: data source: https://hkps.pool.sks-keyservers.net:443 (1) Kristian Fiskerstrand <kf@gnupg.net> Kristian Fiskerstrand <k_f@gentoo.org> Kristian Fiskerstrand <kf@sumptuouscapital.com> Kristian Fiskerstrand <kristian.fiskerstrand@sumptuouscapital.com> 4096 bit RSA key 0B7F8B60E3EDFAE3, created: 2007-12-15, expires: 2020-12-31 ...
$ gpg --version gpg (GnuPG) 2.2.21
Encountered this on 3 machines and it fixed it on 2 machines (Ubuntu Docker and Arch Linux) and the third Arch machine never worked with hkps, only hkp. Despite having the same version of gnupg, no strange configs in ~/gnupg.conf, and on the same network.
Seems that just specifying keyserver pgp.mit.edu in gnupg.conf also fixes it by dropping to the hkp protocol
Pool overview: https://sks-keyservers.net/overview-of-pools.php
2bluesc
  • 141
