dpkg -i /root/Downloads/google-chrome-stable_current_amd64.deb
Selecting previously unselected package google-chrome-stable:amd64.
(Reading database ... 66306 files and directories currently installed.)
Preparing to unpack .../google-chrome-stable_current_amd64.deb ...
Unpacking google-chrome-stable:amd64 (81.0.4044.113-1) ...
dpkg: dependency problems prevent configuration of google-chrome-stable:amd64:
google-chrome-stable:amd64 depends on libappindicator3-1.
google-chrome-stable:amd64 depends on libasound2 (>= 1.0.16).
google-chrome-stable:amd64 depends on libatk-bridge2.0-0 (>= 2.5.3).
google-chrome-stable:amd64 depends on libatk1.0-0 (>= 2.2.0).
google-chrome-stable:amd64 depends on libatspi2.0-0 (>= 2.9.90).
google-chrome-stable:amd64 depends on libc6 (>= 2.16).
google-chrome-stable:amd64 depends on libcairo2 (>= 1.6.0).
google-chrome-stable:amd64 depends on libcups2 (>= 1.4.0).
google-chrome-stable:amd64 depends on libdbus-1-3 (>= 1.5.12).
google-chrome-stable:amd64 depends on libdrm2 (>= 2.4.38).
google-chrome-stable:amd64 depends on libexpat1 (>= 2.0.1).
google-chrome-stable:amd64 depends on libgbm1 (>= 8.1~0).
google-chrome-stable:amd64 depends on libgcc1 (>= 1:3.0).
google-chrome-stable:amd64 depends on libgdk-pixbuf2.0-0 (>= 2.22.0).
google-chrome-stable:amd64 depends on libglib2.0-0 (>= 2.39.4).
google-chrome-stable:amd64 depends on libgtk-3-0 (>= 3.9.10).
google-chrome-stable:amd64 depends on libnspr4 (>= 2:4.9-2~).
google-chrome-stable:amd64 depends on libnss3 (>= 2:3.22).
google-chrome-stable:amd64 depends on libpango-1.0-0 (>= 1.14.0).
google-chrome-stable:amd64 depends on libpangocairo-1.0-0 (>= 1.14.0).
google-chrome-stable:amd64 depends on libx11-6 (>= 2:1.4.99.1).
google-chrome-stable:amd64 depends on libx11-xcb1.
google-chrome-stable:amd64 depends on libxcb-dri3-0.
google-chrome-stable:amd64 depends on libxcb1 (>= 1.6).
google-chrome-stable:amd64 depends on libxcomposite1 (>= 1:0.3-1).
google-chrome-stable:amd64 depends on libxcursor1 (>> 1.1.2).
google-chrome-stable:amd64 depends on libxdamage1 (>= 1:1.1).
google-chrome-stable:amd64 depends on libxext6.
google-chrome-stable:amd64 depends on libxfixes3 (>= 1:5.0).
google-chrome-stable:amd64 depends on libxi6 (>= 2:1.2.99.4).
google-chrome-stable:amd64 depends on libxrandr2 (>= 2:1.2.99.3).
google-chrome-stable:amd64 depends on libxrender1.
google-chrome-stable:amd64 depends on libxss1.
google-chrome-stable:amd64 depends on libxtst6.
dpkg: error processing package google-chrome-stable:amd64 (--install):
dependency problems - leaving unconfigured
Processing triggers for desktop-file-utils (0.23-1ubuntu3) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Processing triggers for man-db (2.8.3-2) ...
- 39
dpkg -i doesn't do any automatic dependency resolution. Try running this command which automatically installs all the dependencies required to install Chrome along with Chrome itself.
sudo apt install ./root/Downloads/google-chrome-stable_current_amd64.deb
If the location at the end of the command is your root account and not your normal user account, please copy or move google-chrome-stable_current_amd64.deb to your normal user's Downloads directory and run the command from there.
- 122,292
- 133
- 301
- 332
first of all, make sure you are in your .deb folder, then, try to reconfigure all dpkg config files and programs running this:
dpkg-reconfigure --all
Then, run this to install dependencies
apt install -f
Next, you should be able to install chrome .deb file
If you get another error, just install chrome via apt, following this steps: First of all, add google repo:
wget -q -O - https://dl-ssl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
Then,
sudo sh -c 'echo "deb https://dl.google.com/linux/chrome/deb/ stable main" >> /etc/apt/sources.list.d/google.list'
and finally:
apt update && apt install google-chrome-stable -y
That should be enough.
- 16
