Here are the contents of /boot:
drwxr-xr-x 5 root root 3072 Apr 18 09:10 .
drwxr-xr-x 26 root root 4096 Mar 22 15:43 ..
-rw-r--r-- 1 root root 217495 Jan 17 05:59 config-4.15.0-76-generic
-rw-r--r-- 1 root root 217457 Feb 28 02:45 config-4.15.0-91-generic
drwxr-xr-x 3 root root 4096 Dec 31 1969 efi
drwxr-xr-x 5 root root 1024 Mar 22 15:50 grub
-rw-r--r-- 1 root root 60196828 Apr 18 09:05 initrd.img-4.15.0-76-generic
-rw-r--r-- 1 root root 60206115 Apr 18 09:05 initrd.img-4.15.0-91-generic
drwx------ 2 root root 12288 Feb 13 2016 lost+found
-rw-r--r-- 1 root root 182704 Jan 28 2016 memtest86+.bin
-rw-r--r-- 1 root root 184380 Jan 28 2016 memtest86+.elf
-rw-r--r-- 1 root root 184840 Jan 28 2016 memtest86+_multiboot.bin
-rw------- 1 root root 4068355 Jan 17 05:59 System.map-4.15.0-76-generic
-rw------- 1 root root 8367768 Jan 17 06:27 vmlinuz-4.15.0-76-generic
-rw------- 1 root root 8375960 Feb 28 02:51 vmlinuz-4.15.0-91-generic
My kernel version is 4.15.0-91-generic (based on uname -r).
The output of dpkg --list | grep linux-image is:
c linux-image-4.15.0-74-generic 4.15.0-74.84 amd64 Signed kernel image generic
ii linux-image-4.15.0-76-generic 4.15.0-76.86 amd64 Signed kernel image generic
ii linux-image-4.15.0-91-generic 4.15.0-91.92 amd64 Signed kernel image generic
ic linux-image-4.4.0-171-generic 4.4.0-171.200 amd64 Signed kernel image generic
This is what happens when I run sudo apt-get upgrade:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
thermald
Use 'sudo apt autoremove' to remove it.
The following packages have been kept back:
linux-headers-generic
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up linux-firmware (1.173.17) ...
update-initramfs: Generating /boot/initrd.img-4.15.0-91-generic
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/x86_64-linux-gnu_EGL.conf: No such file or directory
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/x86_64-linux-gnu_mirclientplatform.conf: No such file or directory
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/x86_64-linux-gnu_mirplatformgraphics.conf: No such file or directory
update-initramfs: Generating /boot/initrd.img-4.15.0-76-generic
update-initramfs: Generating /boot/initrd.img-3.19.0-69-generic
WARNING: missing /lib/modules/3.19.0-69-generic
Ensure all necessary drivers are built into the linux image!
depmod: ERROR: could not open directory /lib/modules/3.19.0-69-generic: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_BapeFK/lib/modules/3.19.0-69-generic/modules.order: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_BapeFK/lib/modules/3.19.0-69-generic/modules.builtin: No such file or directory
update-initramfs: Generating /boot/initrd.img-3.19.0-66-generic
WARNING: missing /lib/modules/3.19.0-66-generic
depmod: ERROR: could not open directory /lib/modules/3.19.0-66-generic: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_oFrhwW/lib/modules/3.19.0-66-generic/modules.order: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_oFrhwW/lib/modules/3.19.0-66-generic/modules.builtin: No such file or directory
update-initramfs: Generating /boot/initrd.img-3.19.0-65-generic
WARNING: missing /lib/modules/3.19.0-65-generic
depmod: ERROR: could not open directory /lib/modules/3.19.0-65-generic: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_cmnh3Q/lib/modules/3.19.0-65-generic/modules.order: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_cmnh3Q/lib/modules/3.19.0-65-generic/modules.builtin: No such file or directory
update-initramfs: Generating /boot/initrd.img-3.19.0-59-generic
WARNING: missing /lib/modules/3.19.0-59-generic
depmod: ERROR: could not open directory /lib/modules/3.19.0-59-generic: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_kimz35/lib/modules/3.19.0-59-generic/modules.order: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_kimz35/lib/modules/3.19.0-59-generic/modules.builtin: No such file or directory
update-initramfs: Generating /boot/initrd.img-3.19.0-58-generic
WARNING: missing /lib/modules/3.19.0-58-generic
depmod: ERROR: could not open directory /lib/modules/3.19.0-58-generic: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_yH46Fl/lib/modules/3.19.0-58-generic/modules.order: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_yH46Fl/lib/modules/3.19.0-58-generic/modules.builtin: No such file or directory
update-initramfs: Generating /boot/initrd.img-3.19.0-25-generic
WARNING: missing /lib/modules/3.19.0-25-generic
depmod: ERROR: could not open directory /lib/modules/3.19.0-25-generic: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_gmb7aZ/lib/modules/3.19.0-25-generic/modules.order: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_gmb7aZ/lib/modules/3.19.0-25-generic/modules.builtin: No such file or directory
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-3.19.0-25-generic with 1.
dpkg: error processing package linux-firmware (--configure):
installed linux-firmware package post-installation script subprocess returned error exit status 1
linux-firmware
Now, the contents of /boot are:
drwxr-xr-x 5 root root 3072 Apr 18 09:14 .
-rw-r--r-- 1 root root 16975438 Apr 18 09:14 initrd.img-3.19.0-58-generic
-rw-r--r-- 1 root root 16975489 Apr 18 09:14 initrd.img-3.19.0-59-generic
-rw-r--r-- 1 root root 16975434 Apr 18 09:14 initrd.img-3.19.0-65-generic
-rw-r--r-- 1 root root 16975144 Apr 18 09:14 initrd.img-3.19.0-66-generic
-rw-r--r-- 1 root root 16975428 Apr 18 09:14 initrd.img-3.19.0-69-generic
-rw-r--r-- 1 root root 60195966 Apr 18 09:14 initrd.img-4.15.0-76-generic
-rw-r--r-- 1 root root 60204841 Apr 18 09:14 initrd.img-4.15.0-91-generic
It appears that the system is trying to build old initrd files in /boot, and then /boot fills up, and then dpkg fails. How can I fix this?
