I'm unable to get an IP address assigned through DHCP during system boot.
I was unable to get either IPV4 or IPv6 working for my NIC enp5s0 (details below) during my vanilla, single disk install of Ubuntu 18.04 Server, so I proceeded without the Network. Unfortunately, I'm unable to configure it properly post installation.
My 01-netcfg.yaml file is below and I did remember to run:
sudo netplan generate
sudo netplan apply
I'm able to get an IP address with this command:
sudo dhclient -v enp5s0
so I updated the installation, but the problem persists. It must be a configuration problem but I can't figure out what it is. Troubleshooting pointers appreciated!
enp5s0
enp5s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.24.1.222 netmask 255.255.255.0 broadcast 172.24.1.255
inet6 fe80::dacb:8aff:fea3:460e prefixlen 64 scopeid 0x20<link>
ether a2:bc:3b:b7:92:3c txqueuelen 1000 (Ethernet)
RX packets 9240 bytes 852219 (852.2 KB)
RX errors 0 dropped 215 overruns 0 frame 0
TX packets 731 bytes 126544 (126.5 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 18
01-netcfg.yaml
network:
version: 2
renderer: networkd
ethernets:
enp5s0:
dhcp4: true
