First off, i'm very new to linux, using it for whole 2 days now.
I'm trying to build an app with QT Creator but I can't use the c++ compiler since it doesn't want to Install.
I Tried installing the build-essential package to use QT properly, these packages installed without any problems:
- dpkg-dev
- gcc
- make
Though libc6 and g++ didn't so I tried installing all their dependencies and it throws me into a weird loop where it says that libc6 is installed.
This is the order I tried to install the package:
:~$ sudo apt install build-essential
Reading package lists... Done
Building dependency tree
build-essential : Depends: libc6-dev but it is not going to be installed or
libc-dev
Depends: g++ (>= 4:7.2) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.```
:~$ sudo apt install libc-dev
Note, selecting 'libc6-dev' instead of 'libc-dev'
libc6-dev : Depends: libc6 (= 2.27-3ubuntu1) but 2.28-0ubuntu1+zorin4 is to be installed
Depends: libc-dev-bin (= 2.27-3ubuntu1)
:~$ sudo apt install libc6
libc6 is already the newest version (2.28-0ubuntu1+zorin4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Now bear In mind that I'm a total noob at linux, so any help would be appreciated.
