When trying to download SWI-Prolog using sudo apt-get install swi-prolog, I got a series of errors:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
libpython3-dev : Depends: libpython3.5-dev (>= 3.5.1-2~) but it is not installable
python3.5-dev : Depends: python3.5 (= 3.5.2-2ubuntu0~16.04.4) but 3.5.2-2ubuntu0~16.04.3 is to be
installed
             Depends: libpython3.5-dev (= 3.5.2-2ubuntu0~16.04.4) but it is not installable
             Depends: libpython3.5 (= 3.5.2-2ubuntu0~16.04.4) but 3.5.2-2ubuntu0~16.04.3 is to be
installed
swi-prolog-nox : Depends: libossp-uuid16 but it is not going to be installed
              Depends: libreadline7 (>= 6.0) but it is not going to be installed
              Depends: libssl1.1 (>= 1.1.0) but it is not going to be installed
              Depends: libedit-dev but it is not going to be installed
              Depends: libgmp-dev but it is not going to be installed
              Depends: libncursesw5-dev but it is not going to be installed
              Depends: libreadline-dev but it is not going to be installed
              Recommends: debhelper but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I did try apt-get -f install, which threw the errors:
Correcting dependencies... failed.
installable
2ubuntu0~16.04.3 is installed
not installable
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by
held packages.
E: Unable to correct dependencies
I also have the same problem(s) when doing a full update using sudo apt-get update or upgrade. How can I fix these errors?
Thanks!
Ollie
  • 3,372
Answering my question.... I had to make a fresh installation of Ubuntu. Now on 20.04.
Ollie
  • 3,372
