I am trying to install Jasmin Gateway on Ubuntu Server 16.04 LTS, but I have the error below:
root@ds234:/home# sudo apt-get install python-jasmin
Reading package lists... Done
Building dependency tree
 python-jasmin : Depends: rabbitmq-server but it is not going to be installed
I tried to install rabbitmq-server:
root@ds234:/home/prodadmin# sudo apt-get install rabbitmq-server -y
 rabbitmq-server : Depends: locales-all
I tried to run the commands below to fix the broken packages but did not install:
sudo dpkg --configure -a
sudo apt-get install -f
sudo apt remove
muru
  • 207,228
David
