I had a working system with dual boot of Win 10 and Ubuntu 18.04 on a single hard disk with the following partition layout (more or less, that is what I remember): - Primary NTFS, 1.5gb boot - Primary NTFS, 120gb win10 - Primary Linux, 100gb Ubuntu, divided to 3 partitions: * Extended 2gb where /boot is mounted * Logical 20gb where / is mounted (OS) * Logical 100gb where /home is mounted
I needed more space for the Ubuntu partition, so I resized the win10 partition. I don't remember if I did it from Ubuntu or win10, but after that Ubuntu stopped booting. I managed to fix it using testdisk, but then win10 stopped booting. The situation now is that when I recover the win10 partition using testdisk it boots, but Ubuntu doesn't. When I recover the Ubuntu partition (also with testdisk) it boots, but win10 doesn't.
Currently I'm in the "win10 boots and Ubuntu doesn't" state. When I boot with a Ubuntu Live CD, this is the output of fdisk -l /dev/sda:
Disk /dev/sda: 232.9 GiB, 250059350016 bytes, 488397168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x8f76ec72
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 3074047 3072000 1.5G 7 HPFS/NTFS/exFAT
/dev/sda2 3084480 244380779 241296300 115.1G 7 HPFS/NTFS/exFAT
/dev/sda3 244381696 248381439 3999744 1.9G 83 Linux
So the 2 partitions at the start of the disk are identified correctly, but 2 out of 3 linux partitions aren't.
The analysis of testdisk is:
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63
Partition Start End Size in sectors
1 * HPFS - NTFS 0 32 33 191 89 26 3072000
2 P HPFS - NTFS 191 89 27 12602 29 35 199378944
3 P Linux 15212 14 35 15461 7 34 3999744
4 E extended LBA 15461 7 35 30401 75 10 240015360
5 L Linux 15461 40 4 17911 157 38 39366656
6 L Linux 19903 134 8 30401 75 10 168646656
So it identifies correctly the linux partition structure, but if I recover it it messes the windows partitions. Note that in this situation the win10 partition has its size before I shrinked it (~120gb) but testdisk identifies it with size after the shrinking (~100gb)
Any way to recover it correctly?
