I am using an Acer Predator Helios 300 Core i7 7th Gen - G3-572 Gaming Laptop(having Nvidia Geforce 1050Ti graphics card). It originally comes with Windows 10 and I made it dual boot and installed Ubuntu 16.04 on it. When I am connecting a monitor to the laptop via HDMI cable, it failed to detect it. When I am doing the same while using Windows 10, it is successfully detecting it. I have tried every solution I found online but unable to solve the issue. Whenever I am installing Nvidia driver, I got stuck in an infinite login loop, unable to solve it either.
Ubuntu Specifications:
  • Processor: Intel® Core™ i7-7700HQ CPU @ 2.80GHz × 8
  • Graphics: llvmpipe (LLVM 6.0, 256 bits)
  • OS type: 64 bit
From above specs, it's clearly visible that Nvidia driver is not Installed. I would really appreciate someone's help/guidance on the same. Thanks in advance!
EDIT : Output of sudo lshw -C display
*-display
       description: VGA compatible controller
       product: GP107M [GeForce GTX 1050 Ti Mobile]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
       configuration: driver=nvidia latency=0
       resources: irq:16 memory:a3000000-a3ffffff memory:90000000-9fffffff memory:a0000000-a1ffffff ioport:4000(size=128) memory:a4080000-a40fffff   *-display UNCLAIMED
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 04
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm vga_controller bus_master cap_list
       configuration: latency=0
       resources: memory:a2000000-a2ffffff memory:b0000000-bfffffff ioport:5000(size=64) memory:c0000-dffff
Ubuntu 16.04 was a pain to get any Nvidia drivers working. Next week Ubuntu 20.04 is being released and I'd recommend Ubuntu 18.04 or 20.04.
Considering you have a decent and newer Nvidia card. This site helped me get Nvidia working a few years ago. Do all your updates and upgrades first. Maybe even do-release-upgrade and move up to 18.04.
I recommend proprietary drivers for Nvidia cards, skip the open source.
https://www.cyberciti.biz/faq/ubuntu-linux-install-nvidia-driver-latest-proprietary-driver/
Unable to install Nvidia drivers on Ubuntu 18.04.1
https://linuxconfig.org/how-to-install-the-nvidia-drivers-on-ubuntu-18-04-bionic-beaver-linux
Found this based on lshw output from: lshw -C display shows UNCLAIMED for GT840M graphics card
Secure Boot does not let the nvidia module load.
Disable Secure boot in BIOS and it should be solved.
You can see this question for more information.
Czar
  • 610
