Somehow both gcc-7 and gcc-9 were removed from my Ubuntu 18.04.4 arm64 system and we need these to compile our code. To me, it seems like an update to libgcc-s1 as of 04-05-2020 has broken the arm64 compatibility for these in 18.04. Does anyone have a solution or workaround?
When I try to reinstall them I get:
$ sudo apt-get install gcc-9 g++-9 gcc-7 g++-7
Reading package lists... Done
Building dependency tree
g++-7 : Depends: libstdc++-7-dev (= 7.5.0-3ubuntu1~18.04) but it is not going to be installed
g++-9 : Depends: libstdc++-9-dev (= 9.2.1-17ubuntu1~18.04.1) but it is not going to be installed
gcc-7 : Depends: libgcc-7-dev (= 7.5.0-3ubuntu1~18.04) but it is not going to be installed
gcc-9 : Depends: libgcc-9-dev (= 9.2.1-17ubuntu1~18.04.1) but it is not going to be installed
if I try to install these dependencies I get:
$ sudo apt install libstdc++-9-dev libgcc-9-dev libstdc++-7-dev libgcc-7-dev
libgcc-s1 : Breaks: libgcc-7-dev (< 7.5.0-4) but 7.5.0-3ubuntu1~18.04 is to be installed
Breaks: libgcc-9-dev (< 9.2.1-26) but 9.2.1-17ubuntu1~18.04.1 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I have checked that there are no held packages and found no available updates for libgcc-s1. I am using the repo ubuntu-toolchain-r/test and my libgcc-s1 is version 10-20200405-0ubuntu1~18.04.
Update 07/08: We updated our code to be compatible to gcc10 g++10 and were able to install those successfully.
