I installed a second SSD in my Dell laptop's optical drive bay. I want to install Ubuntu 18.04.4 to dual boot with Windows 10. I created a bootable USB with Rufus. I disabled Windows fast startup and secure boot in BIOS, set USB as first boot device, and checked UEFI mode (not legacy). Then, the installation starts normally.
I choose to install Ubuntu alongside Windows 10 (the first option... this option also creates an /dev/sda for NTFS and I don't know why...) and everything is fine until it says to restart the computer.
After restart, I see only the grub command line (as you can see in the picture below) and I don't know what to do.
If I use ls, I can see some partions but nothing else not even in partitons.
If I change boot priority, I can only boot Windows 10.
In BIOS, UEFI it says in windows SSD, in USB bootable (which was made with Rufus) and not in the SSD with Ubuntu.
picture of grub command line
How may I solve this so I can choose Ubuntu or Windows and successfully boot either?
  • I used boot repair and even though it was successfully repaired, you can see the report here, I still have the same problem.
  • I installed the ssd with Ubuntu in my desktop pc and it worked perfectly there... (I also have there, a separate ssd with windows 10 installed)
Orion
It sounds like there is some kind of problem with grub, the bootloader. Try booting off the USB stick again and use boot-repair as outlined here. That usually fixes most issues.
If that doesn't work, please post a link to the summary report boot-repair creates.
Good luck!
Béné
  • 1,026
