I'm new to Linux and learning. I'm not the person that set these systems up - but I need to understand and manage them now.
In /etc/netplan - both 01-netcfg.yaml and 50-cloud-init.yaml exist.
The 01 file - is static - showing 192.168.100.30 the 50 file - is dhcp
the 100.30 address is visible when I do an ipconfig -a. The 100.50 address is not visible anywhere that I have found. I don't need dhcp - the server should be set to the 100.30 static IP only.
Can I simply delete the 50-cloud-init.yaml file - or what is best practice?
results of ifconfig -a:
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:c0:4b:ea:91 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.100.30 netmask 255.255.255.0 broadcast 192.168.100.255
inet6 fe80::215:5dff:fe00:700e prefixlen 64 scopeid 0x20<link>
ether 00:15:5d:00:70:0e txqueuelen 1000 (Ethernet)
RX packets 17211039 bytes 1688816727 (1.6 GB)
RX errors 0 dropped 4 overruns 0 frame 0
TX packets 137882 bytes 550823194 (550.8 MB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 11147 bytes 843462 (843.4 KB)
TX packets 11147 bytes 843462 (843.4 KB)
@heynnema Contents of 01-netcfg.yaml
network:
version: 2
renderer: networkd
ethernets:
eth0:
dhcp4: no
addresses: [192.168.100.30/24]
gateway4: 192.168.100.1
nameservers:
addresses: [192.168.100.26,192.168.100.19,8.8.8.8,8.8.4.4]
Contents of 50-cloud-init.yaml
# This file is generated from information provided by
# the datasource. Changes to it will not persist across an instance.
# To disable cloud-init's network configuration capabilities, write a file
# /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following:
# network: {config: disabled}
network:
ethernets:
eth0:
addresses: []
dhcp4: true
version: 2
Contents of /etc/netork/interfaces:
# ifupdown has been replaced by netplan(5) on this system. See
# /etc/netplan for current configuration.
# To re-enable ifupdown on this system, you can run:
# sudo apt install ifupdown
