root@tet0-Lenovo-G500s:/home/tet0/Downloads# apt install ./anydesk_5.5.4-1_amd64.deb
Reading package lists... Done
Building dependency tree
Note, selecting 'anydesk:amd64' instead of './anydesk_5.5.4-1_amd64.deb'
 anydesk:amd64 : Depends: libc6:amd64 (>= 2.7) but it is not installable
                 Depends: libgcc1:amd64 (>= 1:4.1.1) but it is not installable
                 Depends: libglib2.0-0:amd64 (>= 2.16.0) but it is not installable
                 Depends: libgtk2.0-0:amd64 (>= 2.20.1) but it is not installable
                 Depends: libstdc++6:amd64 (>= 4.1.1) but it is not installable
                 Depends: libx11-6:amd64 but it is not installable
                 Depends: libxcb-shm0:amd64 but it is not installable
                 Depends: libxcb1:amd64 but it is not installable
                 Depends: libpango1.0-0:amd64 but it is not installable
                 Depends: libcairo2:amd64 but it is not installable
                 Depends: libxrandr2:amd64 (>= 1.3) but it is not installable
                 Depends: libx11-xcb1:amd64 but it is not installable
                 Depends: libxtst6:amd64 but it is not installable
                 Depends: libxfixes3:amd64 but it is not installable
                 Depends: libxdamage1:amd64 but it is not installable
                 Depends: libxkbfile1:amd64 but it is not installable
                 Depends: libgtkglext1:amd64 but it is not installable
                 Recommends: libglx-mesa0:amd64 but it is not installable
Satyajit
  • 111
If I'm not mistaken, you've installed a 32 bit version of ubuntu. Then you need a 32 bit deb file - and you tried to install the 64 bit. First you need to remove the "wrong" deb version.
Then update.
sudo apt update
Select and install the 32 bit deb version from Anydesk and you should be fine
Ubuntu will cease to support 32 bit. So it is a good idea to install a 64bit operating system on your Lenovo G500s (which has a 64 bit Windows by default)
kanehekili
  • 7,426
