I want to use Ubuntu but I'm not sure if it will work for Microsoft Visual Studios C++ 2010. Or is there another program that will work on Ubuntu that will work just as good (if not better) than Visual Studios?
Syrose
5 Answers5
Visual Studio would run like death on Ubuntu, but if C++ is your target language, there are way better options out there, many of which are free.
Try Eclipse: http://www.eclipse.org/ or Code::Blocks: http://www.codeblocks.org/
Both are very popular.
Musaab
  • 503
Visual Studio
As per Wine HQ, Visual Studio performs horribly on Wine.
Visual Studio 2008 (9.0) Express Edition - Bronze
What works
  • Installing using the workaround for Bug #9158.
  • Using the IDE to build and generate a DLL.
What does not
  • Installing without using the workaround.
  • On start the "Visual Studio Explorers and Designers Package" fails to load.
  • Build seems to sometimes get stuck at "Generating Code...", restarting the IDE and building again allows you to proceed.
Visual Studio 2010 Express - Garbage
What works
  • Nothing
What does not
  • Everything
Visual Studio 2010 Professional - Garbage
What works
  • Installer
What does not
  • Everything else
Visual Studio 2010 Ultimate - Garbage
What works
  • Open the installer
What does not
  • Installing part of Visual Studio 2010
Visual Studio 2011 Ultimate Beta - Garbage
What works
  • Nothing.
What does not
  • Installing with netinstall fails with #(loc.FailedHeader)
Monodevelop
The only other option for opening .sln files on Linux is Monodevelop. Lots of features which you expect in Visual Studio are missing.
Manish Sinha
  • 11,671
For C++ Development on Ubuntu, Eclipse is your best bet, and the easiest way to get the Eclipse IDE is:
sudo apt-get install eclipse
Kilizo
  • 929
Visual Studio 2008 works good with a workaround and it's possible to use the IDE and create a DLL. Visual Studio 2010 hasn't been tested on Wine 1.4 and 1.5 and doesn't work on Wine 1.3.
Install instructions for 2008:
  • Install Wine 1.4 or 1.5
  • Create an empty Wineprefix: open a terminal window and enter
WINEPREFIX="$HOME/.vs2008" winecfg
  • Download Winetricks:
wget http://kegel.com/wine/winetricks
  • Install .NET Framework 3:
WINEPREFIX="$HOME/.vs2008" bash winetricks -q dotnet35­
  • Install Visual Studio 2008:
from online installer use this workaround:
WINEPREFIX="$HOME/.vs2008" _SFX_CAB_SHUTDOWN_REQUEST=1 wine ./vcssetup.exe
or from CD or ISO:
WINEPREFIX="$HOME/.vs2008" wine ./autorun.exe
Source: http://appdb.winehq.org/objectManager.php?sClass=version&iId=11210
Install instructions for 2010:
WINEPREFIX="$HOME/.vs2010" winecfg
WINEPREFIX="$HOME/.vs2010" bash winetricks dotnet20 dotnet40
  • Install Visual Studio 2010:
WINEPREFIX="$HOME/.vs2010" _SFX_CAB_SHUTDOWN_REQUEST=1 wine ./vcssetup.exe
or from CD or ISO:
WINEPREFIX="$HOME/.vs2010" wine ./autorun.exe
Source: http://appdb.winehq.org/objectManager.php?sClass=version&iId=22306
nastys
  • 5,427
I know this is an older post, but if anyone comes here afterwards by means of a Google search, and you don't want to go through the WINE setup...
CodeLite - http://codelite.org - is a great open source, cross platform IDE for C/C++. It is much like CodeBlocks but a lot simpler for beginners and/or new users, and it has an option for opening .sln files for VS projects.
I am sure there are also .sln plugins for CodeBlocks but CodeLite has that already loaded and easy to find. http://codelite.org has every download type including apt links which open up Ubuntu Software Center.
SudoSURoot
  • 2,849
  • 15
  • 16
