I have added the PPA to install WoeUSB on Ubuntu 20.04.
sudo add-apt-repository ppa:nilarimogard/webupd8
Then I tried to install WoeUSB.
martin@slazer:~/Downloads$ sudo apt install woeusb
Reading package lists... Done
Building dependency tree
woeusb : Depends: libwxgtk3.0-0v5 (>= 3.0.4+dfsg) but it is not installable
There was a missing package so I searched for it and installed it.
martin@slazer:~/Downloads$ sudo apt-cache search libwxgtk3.0
libwxgtk3.0-gtk3-0v5 - wxWidgets Cross-platform C++ GUI toolkit (GTK 3 runtime)
libwxgtk3.0-gtk3-dev - wxWidgets Cross-platform C++ GUI toolkit (GTK 3 development)
However, the same error persists. I think it's just a labeling issue since libwxgtk3.0-0v5 and libwxgtk3.0-gtk3-0v5 are very similar. If it is so, is it possible to somehow trick Ubuntu to recognize the package under different name - perhaps using symbolic links?
