12
I am interested in running a bash script which starts an application (in this case VLC), run it for a certain amount of time and then stop it. I can get this application to start just fine, but it will not stop, using this script:
#!/usr/bin/bash
vlc -vvv http://10.0.0.113:8000/stream.mjpg --sout="#std{access=file,mux=ogg,dst=/home/whsrobotics/vlc_project/first_try.mp4}"
sleep 10
killall vlc
Not only does it not stop the stream recording, but the app seems to freeze sometimes after I hit Ctrl+Z.
Any suggestions are appreciated.
Pablo Bianchi
  • 17,371
SteveC
  • 253
You can use the timeout command to run a command with a time limit. Its basic syntax is:
timeout DURATION COMMAND
where DURATION is a floating point number with the suffix s for seconds, m for minutes, h for hours or d for days and COMMAND is the command you wish to run.
In your case, you can use:
timeout 10s vlc -vvv http://10.0.0.113:8000/stream.mjpg --sout="#std{access=file,mux=ogg,dst=/home/whsrobotics/vlc_project/first_try.mp4}"
to run your command for 10 seconds and then kill it.
Add & after the second line to put VLC in the background like so:
#!/usr/bin/bash
vlc -vvv http://10.0.0.113:8000/stream.mjpg --sout="#std{access=file,mux=ogg,dst=/home/whsrobotics/vlc_project/first_try.mp4}" &
sleep 10
killall vlc
and it will work.
Explaination:
The shell/terminal will execute commands in the order they are listed in the script and will move to the next command only if the command before it finishes executing.
Which is not the case in your VLC command. As long as VLC is running, the shell/terminal will consider it still executing and will not move to the command after it but will rather wait for it to finish executing ( ie. in this case closing the VLC window/instance ).
A workaround this is to send VLC to the background and free the shell/terminal prompt for the next command in the script. Which can be done by adding & after the command.
Notice:
  • Remove verbosity option -vvv to avoid the script not exiting cleanly and completely.
  • If, however, you have to use the verbosity option -vvv add nohup before the second line as well like so:
#!/usr/bin/bash
nohup vlc -vvv http://10.0.0.113:8000/stream.mjpg --sout="#std{access=file,mux=ogg,dst=/home/whsrobotics/vlc_project/first_try.mp4}" &
sleep 10
killall vlc
This will append output to a file called nohup.out in the current working directory if possible or to ~/nohup.out otherwise and will allow the script to terminate cleanly and completely.
See man nohup for information.
Best of luck
Raffa
  • 34,963
This is probably the most elegant answer (only works with VLC of course):
#!/usr/bin/bash
vlc -vvv --stop-time 10 --play-and-exit http://10.0.0.113:8000/stream.mjpg --sout="#std{access=file,mux=ogg,dst=/home/whsrobotics/vlc_project/first_try.mp4}"
--stop-time 10 Will stop playback after 10 seconds
--play-and-exit Will exit VLC after playback stopped (default is --no-play-and-exit)
In some cases you need to use --run-time instead of --stop-time.
confetti
  • 131
I am pretty sure that this question will be found by people wanting to stop other programs, not just vlc on systems that do not have the timeout command, so in extension to the already good generic answer by Raffa:
Your attempt would kill all vlc processes in the system, not just the one started by this script. Instead you can use the kill built-in, as it can accept a bash job specification. For example:
#!/usr/bin/bash
vlc -vvv http://… &
sleep 10
kill %?vlc
The & operator in the second line will create a background bash job. Then kill %?vlc will kill the bash job whose prefix is vlc.
liori
  • 839
