Is there another way to pass this log in site. Because i have more the 5 years trying to open it.
Asked
Active
Viewed 251 times
What distro are you running? If it's ubuntu based, when you turn it on you can hold down the shift key as soon as you power it on to access the grub menu. When you are in the grub menu, select advanced options. Then select ubuntu (recovery mode). Now go to the root option. It should be near the bottom. Next, remount the root partition with this command:
mount -rw -o remount /
Now to reset the password, just type
ls /home | grep `^d' | passwd $USER
Then type your password and you are done! Hope this helps.
