I have a fresh installation of Xubuntu 18.04. I have installed driver nvidia-driver-440. When I switch to Nvidia (prime-select nvidia) my system will not boot. It will stop at black screen with a blinking white cursor. The only way to get back is to run in recovery mode and switch to intel back. Is there a way to fix this issue?
$: sudo lshw -c Display
*-display UNCLAIMED
description: 3D controller
product: GM107M [GeForce GTX 960M]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:02:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: latency=0
resources: memory:de000000-deffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:e000(size=128) memory:df000000-df07ffff
*-display
description: VGA compatible controller
product: HD Graphics 530
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:134 memory:dd000000-ddffffff memory:b0000000-bfffffff ioport:f000(size=64) memory:c0000-dffff
I found similar problem Nvidia Plugin causing black screen on Ubuntu LTS 18.04 but the solution doesn't help me
Update
Looks like the problem is not in Linux and drivers. I have same problem while running Windows.
