I am working with Ubuntu
  • Server and Desktop
and both are based with the 18.04 version
I need work with vim - by default it is installed in Server - it has the 8.0.1453 version.
But in the Desktop is not installed, therefore for the Desktop I did the following:
  • sudo apt update
  • sudo apt upgrade
  • sudo apt install vim
All ok, Vim is installed how is expected but again it is based for the 8.0.1453 version.
Even if in the Server I do
  • sudo apt update
  • sudo apt upgrade
Nothing to update but Vim remains with the 8.0.1453 version
I am confused because in Vim - Download page has the following note:
Version
Vim 8.2 is the latest stable version. It is highly recommended, many bugs have been fixed since previous versions.
Therefore from 8.0.1453 to 8.2 there is a considerable difference between the releases.
I am assuming that I should do a reference for a special 'repository' (I had this experience through MySQL), which one? and from where I should take that 'official' reference?
This is what the download page you've linked to suggests:
Unix
The best way to install Vim on Unix is to use the sources. This requires a compiler and its support files. Compiling Vim isn't difficult at all. You can simply type "make install" when you are happy with the default features. Edit the Makefile in the "src" directory to select specific features.
You need to download at the sources and the runtime files. And apply all the latest patches. For Vim 6 up to 7.2 you can optionally get the "lang" archive, which adds translated messages and menus. For 7.3 and later this is included with the runtime files.
Using git This is the simplest and most efficient way to obtain the latest version, including all patches. This requires the "git" command. The explanations are on the GitHub page.
Summary:
git clone https://github.com/vim/vim.git
cd vim/src
make
Using Mercurial This is another simple and most efficient way to obtain the latest version, including all patches. This requires the "hg" command. The explanations are on this page: Mercurial
Summary:
hg clone https://bitbucket.org/vim-mirror/vim
cd vim/src
make
You are probably ok with version 8.0.1453, but good luck anyway.
mikewhatever
  • 33,013
