$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
$ cat /proc/asound/modules
1 snd_hda_intel
$ lspci -v | grep -A7 -i "audio"
00:1f.3 Multimedia audio controller: Intel Corporation Cannon Lake PCH cAVS (rev 10)
Subsystem: Dell Device 0949
Flags: bus master, fast devsel, latency 32, IRQ 16
Memory at a5318000 (64-bit, non-prefetchable) [size=16K]
Memory at a5000000 (64-bit, non-prefetchable) [size=1M]
Capabilities: <access denied>
Kernel driver in use: snd_soc_skl
Kernel modules: snd_hda_intel, snd_soc_skl, sof_pci_dev
01:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at a3080000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
You will need to add an option on GRUB.
To edit grub options:
sudo nano /etc/default/grub
Find GRUB_CMDLINE_LINUX_DEFAULT and add snd_hda_intel.dmic_detect=0 to the end of it. It will look something like this:
GRUB_CMDLINE_LINUX_DEFAULT="loglevel=3 snd_hda_intel.dmic_detect=0"
Then rebuild grub menu:
sudo grub-mkconfig -o /boot/grub/grub.cfg
After you reboot the system the device should work.
- 351
For me the solution was to install the latest Sound Open Firmware (SOF) binaries from here: https://github.com/thesofproject/sof-bin
Specifically:
- Clone the repository:
git clone https://github.com/thesofproject/sof-bin.git - Change to directory:
cd sof-bin - Follow: https://github.com/thesofproject/sof-bin#install-process-with-installsh (for me v2.2 worked)
sudo mv /lib/firmware/intel/sof* some_backup_location/
sudo mv /usr/local/bin/sof-* some_backup_location/ # optional
sudo ./install.sh v2.2.x/v2.2
- Reboot
After this the sound output as well as the microphone were working (Ubuntu 23.04, Lenovo X1 Gen8)
Note: Make sure that the snd_hda_intel.dmic_detect=0 or snd_intel_dspcfg.dsp_driver=1 settings are not set in GRUB_CMDLINE_LINUX_DEFAULT or /etc/modprobe.d/alsa-base.conf. Otherwise the sound output may work but no microphone input.
Related question/answer: https://askubuntu.com/a/1424600/142531
- 33
