When I try to install Ubuntu 18.04.4 LTS (on a bootable USB; after I select "Install Ubuntu" in the GRUB boot loader), the screen turns black for a few seconds, then lines and dots appear on the screen. In the top area, there are 2 lines (multi-colored), and at the bottom there are a bunch of dots, as if there was a black piece of paper covering the screen but I poked a bunch of (small) holes though the paper.
I'm using a NVIDIA GeForce RTX 2070 Super.
I have tried the following with no success:
  • Using a different USB port
  • Using a different USB bootable drive creator (Rufus v3.9 and balenaEtcher v1.5.80)
  • Re-downloading the ISO (from https://ubuntu.com/download/desktop)
Does anyone know what is happening? Also, I have Windows 10 installed on the same disk, maybe that has something to do with it?
Here is a video of what I am doing.
Pablo Bianchi
  • 17,371
Newo
  • 330
I had the same problem and I solve this situation. Firstly I use nomodeset and then install and open Linux. After this, open a terminal and write this
sudo add-apt-repository ppa:graphics-drivers/ppa && sudo apt update
and then open Software & Updates -> Additional Driver then select you wanted to use which graphic drivers and apply. Then restart pc. I solve it this way.
Reference link (for driver install).
Pablo Bianchi
  • 17,371
frht
  • 26
This is old, but from the video it looks like you should try the top option in grub, "try ubuntu" and only install it when it is up and running (the option "install ubuntu" will appear on the desktop).
Dom H
  • 51
