To create symlinks I use:
ln -s /folder /target
But when I delete a file from /target it also get removed from /folder. However I want to keep the file in /folder even though I remove it from /target. How can I do that?
Ravexina
  • 57,256
That's the default and correct behavior.
As you know, /target is just a symbolic link to /folder. When you go inside /target, the files you see are actually living inside /folder. These are actual files and not symbolic links. So when you delete them, you are deleting the actual files living in /folder.
In other words, creating a symlink to a directory does not creates a link for each file/directory inside that directory.
What to do?
Now we know that we have to create a symbolic link for each and every file in "folder". To do that use cp:
cp -rs /folder /target
or as mentioned in the comments to get hard links:
cp -rl /folder /target
You can also use lnddir.
Ravexina
  • 57,256
