Because of the whole Covid-19-situation I need to be able to use Skype on my relatively new Dell Vostro 5590 laptop. Unfortunately I can't get the webcam to work. It shows me a black screen (in Skype and Cheese and what-have-you). I also installed guvcview, but that hasn't proven useful. It's an integrated HD webcam. I already checked that my user is added to the video group.
Any help is appreciated... Is there a special linux driver that I can install?
Not sure what info to provide, but here is the output of lsusb:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0bda:565a Realtek Semiconductor Corp.
Bus 001 Device 003: ID 8087:0aaa Intel Corp.
And lspci gives
00:00.0 Host bridge: Intel Corporation Device 9b61 (rev 0c)
00:02.0 VGA compatible controller: Intel Corporation Device 9b41 (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0c)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Device 02f9
00:13.0 Serial controller: Intel Corporation Device 02fc
00:14.0 USB controller: Intel Corporation Device 02ed
00:14.2 RAM memory: Intel Corporation Device 02ef
00:14.3 Network controller: Intel Corporation Device 02f0
00:15.0 Serial bus controller [0c80]: Intel Corporation Device 02e8
00:16.0 Communication controller: Intel Corporation Device 02e0
00:17.0 SATA controller: Intel Corporation Device 02d3
00:1c.0 PCI bridge: Intel Corporation Device 02bc (rev f0)
00:1d.0 PCI bridge: Intel Corporation Device 02b0 (rev f0)
00:1d.4 PCI bridge: Intel Corporation Device 02b4 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device 0284
00:1f.3 Multimedia audio controller: Intel Corporation Device 02c8
00:1f.4 SMBus: Intel Corporation Device 02a3
00:1f.5 Serial bus controller [0c80]: Intel Corporation Device 02a4
01:00.0 3D controller: NVIDIA Corporation Device 1d13 (rev a1)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
03:00.0 Non-Volatile memory controller: Device 1e0f:0001
But I think there's no webcam info in there... Also when I look through the information I get from dmesg | less I see:
[    2.311696] uvcvideo 1-6:1.0: Entity type for entity Realtek Extended Controls Unit was not initialized!
and
[    2.311740] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input6
[    2.311797] usbcore: registered new interface driver uvcvideo
[    2.311798] USB Video Class driver (1.1.1)
But I don't know what I can do with that! Any suggestions? A little note: Ubuntu was not preinstalled on this laptop. I installed it myself.
EDIT: I launched gucview and tried to capture some photos. I got this in terminal:
ALSA lib pcm_dmix.c:1052:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:867:(find_matching_chmap) Found no matching channel map
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Thanks and stay healthy!
Check if there is some kind of switch to activate the webcam, like the keys: fn + CAM. If there is not, look if there is some physical switch on the side of the notebook. If there is none, try to find in the BIOS options if there is some set to activate the camera. Some DELL models have a panel called "Miscellaneous Devices".
Jonatã
  • 351
From your "lsusb" output, this is your webcam:
So, yes, it is being seen. The Linux Hardware database shows that kernels 3.7 and greater support it. See:
https://linux-hardware.org/index.php?id=usb:0bda-565a
Cool! Ubuntu 18.04 is on kernel 4.15 (or newer if updated) so you are all set there. Hmm. So it looks like the uvc driver should do it out of the box.
Is something blocking your camera from being on? Check the BIOS, any physical switches on your laptop, any keys on the keyboard that turn the camera on or off, or a setting in gnome settings.
In addition, you can install v4l-utils.
sudo apt install v4l-utils
more info: https://launchpad.net/ubuntu/+source/v4l-utils
This is a bunch of command line tools to test out your camera. The command "qv4l2", for instance, will launch a detailed and somewhat complex program for testing your camera. Could get you somewhere.
Best
Smoking
For me (Lenovo IdeaPad running Ubuntu 18.04 as guest under VMWare) the USB emulation has to be set to 3.0 then the camera worked.
For my Dell latitude Laptop, i have disabled secure boot by pressing F2 on boot menu. Tested using cheese and worked.
chinhx@chinhx-Latitude-7280:~$ ls -la /dev/video* crw-rw-rw-+ 1 root video 81, 0 Jul 6 16:38 /dev/video0 crw-rw-rw-+ 1 root video 81, 1 Jul 6 16:38 /dev/video1
