I currenltly run Kubuntu on my dell laptop I need to change the distro from Kubuntu to kubuntu I have tried to run distro upgrade and release upgrade but that didnt help as its the latest Kubuntu release.
Is there a way to update to ubuntu via cli from kubuntu.
You want to switch to ubuntu from the command line right?
You must first update Kubuntu and then switch to the default desktop environment:
  • Upgrade Kubuntu:
    do-release-upgrade
  • Install GNOME and gdm3:
    sudo apt install ubuntu-desktop gnome-shell gdm3
A "Default display manager" menu should appear. Choose gdm3 as default and reboot system.
After the system restarts, it will be received by the GDM. Choose Ubuntu as your desktop environment.
If you want to remove kubuntu, you must follow these commands:
sudo apt autoremove plasma* sddm
sudo apt autoremove kde* qml-module-org-kde* libkf5kdelibs4support* libkf5libkdepim* software-properties-kde xdg-desktop-portal-kde libkde* konsole
After that you should have your Ubuntu system working properly.
gahmasec
  • 94
