I am setting up a Linux machine to as a Plex server. I was also hoping to use it to stream steam games.
I am running the following:
  • Ubuntu 18.04.4 LTS
  • 4 GB RAM 2400mhz
  • Intel i3-8100
  • integrated graphics
  • 6 TB hdd
I also have a 1 tb HDD
Whenever I move large large video files from one hard drive to the other, the machine grinds to a halt. The cursor won't even move for seconds or minutes at a time.
I have adjusted the following:
  • Swappiness to 10 from the default 60
  • Enabled Drive Caching
  • Switched I/O Scheduling to [BFQ] (do I have to do this for each drive)
What other information would be useful. I ran "Top" and there was plenty of CPU and Memory available.
Any thoughts? do you need any more information?
Any help would be greatly appreciated. I have an SSD, but I'd rather not put it in this server.
EDIT:
I did Read benchmarks on each of the HDD: they average about 160MBs
free -h. AND -i swap /etc/fstab
Solution: It was a hardware issue.
muru
  • 207,228
RAM vs swap
  • Setting vm.swappiness=10 is wrong wrong wrong for 4G RAM with an i3. This is why your file copies fail. Set it back to 60 now... and we may change it more later.
  • Set drive caching and I/O Scheduling back to default.
  • free -h and grep -i swap /etc/fstab show me 4G RAM and a 2G /swapfile. The /swapfile is probably too small for your system, so we'll make it twice the size, like this:
Bigger /swapfile
Warning: Be careful. Improper use of the dd command can cause file loss. Best to copy/paste.
free -h                   # confirm 4G RAM and 2G swap
sudo swapoff -a           # turn off swap
sudo rm -i /swapfile      # remove old /swapfile
sudo dd if=/dev/zero of=/swapfile bs=1M count=4096
sudo chmod 600 /swapfile  # set proper file protections
sudo mkswap /swapfile     # init /swapfile
sudo swapon /swapfile     # turn on swap
free -h                   # confirm 4G RAM and 4G swap
reboot                    # reboot and verify operation
Update #1:
Although the larger swap file helped, it didn't entirely fix the problem. User swapped out HDD for SSD, and it's all working ok now. Maybe some bad blocks on the HDD?
Update #2:
To bad block your old HDD...
Note: do NOT abort a bad block scan!
Note: do NOT bad block a SSD
Note: backup your important files FIRST!
Note: this will take many hours
Note: you may have a pending HDD failure
Boot to a Ubuntu Live DVD/USB in “Try Ubuntu” mode.
In terminal...
sudo fdisk -l # identify all "Linux Filesystem" partitions
sudo e2fsck -fcky /dev/sdXX # read-only test
or
sudo e2fsck -fccky /dev/sdXX # non-destructive read/write test (recommended)
The -k is important, because it saves the previous bad block table, and adds any new bad blocks to that table. Without -k, you loose all of the prior bad block information.
The -fccky parameter...
   -f    Force checking even if the file system seems clean.
   -c    This option causes e2fsck to use badblocks(8) program  to  do  a
         read-only  scan  of  the device in order to find any bad blocks.
         If any bad blocks are found, they are added  to  the  bad  block
         inode  to  prevent them from being allocated to a file or direc‐
         tory.  If this option is specified twice,  then  the  bad  block
         scan will be done using a non-destructive read-write test.
   -k    When combined with the -c option, any existing bad blocks in the
         bad blocks list are preserved, and any new bad blocks  found  by
         running  badblocks(8)  will  be added to the existing bad blocks
         list.
   -y    Assume  an answer of `yes' to all questions; allows e2fsck to be
         used non-interactively.  This option may not be specified at the
         same time as the -n or -p options.
heynnema
  • 73,649
