After installing Kali Linux, I then shrank the partition and installed Ubuntu on the available space. The problem I'm now getting is when I restart my laptop, the following Kali Linux menu appears with no options to boot to Ubuntu:
  • Kali GNU/Linux
  • Advanced options for Kali GNU/Linux
  • System setup
However, when I select System setup and then press the F9 key, I get the following Boot Manager page:
Boot Option Menu:
  • OS boot Manager (UEFI) - Kali (HGST HTS545050A7E680)
  • OS boot Manager (UEFI) - ubuntu (HGST HTS545050A7E680)
  • Boot From EFI File
When i select OS boot Manager (UEFI) - ubuntu, the GNU GRUB version 2.02 menu appears:
  • Ubuntu
  • Advanced options for Ubuntu
  • Kali GNU/Linux Rolling (on /dev/sda2)
  • Advanced options for Kali GNU/Linux Rolling (on /dev/sda2)
  • System setup
This is the only menu I want to appear when my laptop first boots. How do I fix this?
EDIT @zerdecal sudo update-grub
EDIT 2 @oldfred sudo efibootmgr -o 0,1
Sparky
  • 133
You could try update-grub to see if that will detect Ubuntu. This should check to see what operating systems are installed and update the grub
Bengü
  • 56
