I have Ubuntu 16.04.6 LTS (GNU/Linux 5.4.10-x86_64-linode132 x86_64) Try to update to 18 but get some errors. When i make do-release-upgrade i get
An unresolvable problem occurred while calculating the upgrade.
This was likely caused by: * Unofficial software packages not provided by Ubuntu Please use the tool 'ppa-purge' from the ppa-purge package to remove software from a Launchpad PPA and try the upgrade again.
If none of this applies, then please report this bug using the command 'ubuntu-bug ubuntu-release-upgrader-core' in a terminal.If you want to investigate this yourself the log files in '/var/log/dist-upgrade' will contain details about the upgrade. Specifically, look at 'main.log' and 'apt.log'.
grep Broken /var/log/dist-upgrade/apt.log
Broken systemd-sysv:i386 Conflicts on systemd-shim [ i386 ] < 9-1bzr4ubuntu1 > ( admin ) Broken systemd-sysv:i386 Conflicts on upstart-sysv [ i386 ] < 1.13.2-0ubuntu21.1 > ( admin ) Broken systemd:i386 Conflicts on upstart [ i386 ] < 1.13.2-0ubuntu21.1 > ( admin ) Broken imagemagick-6-common:i386 Breaks on libmagickcore-6.q16-2 [ i386 ] < 8:6.8.9.9-7ubuntu5.15 > ( libs ) (< 8:6.9.6.2+dfsg-3~) Broken perl:i386 Depends on perl-modules-5.26 [ i386 ] < none -> 5.26.1-6ubuntu0.3 > ( perl ) (>= 5.26.1-6ubuntu0.3) Broken libperl5.26:i386 Depends on perl-modules-5.26 [ i386 ] < none -> 5.26.1-6ubuntu0.3 > ( perl ) (>= 5.26.1-6ubuntu0.3) Broken libdpkg-perl:i386 Depends on perl [ i386 ] < none -> 5.26.1-6ubuntu0.3
( perl ) Broken dpkg-dev:i386 Depends on perl:any [ any ] < none -> > ( none ) Broken poppler-data:i386 Breaks on gs-cjk-resource [ i386 ] < 1.20100103-3 > ( text ) (<= 1.20100103-3) Broken libalgorithm-merge-perl:i386 Depends on perl [ i386 ] < none -> 5.26.1-6ubuntu0.3 > ( perl ) Broken libalgorithm-diff-xs-perl:i386 Depends on perl [ i386 ] < none -> 5.26.1-6ubuntu0.3 > ( perl ) (>= 5.26.1-4) Broken libfile-fcntllock-perl:i386 Depends on perl [ i386 ] < none -> 5.26.1-6ubuntu0.3 > ( perl ) (>= 5.26.0-4) Broken libalgorithm-diff-perl:i386 Depends on perl [ i386 ] < none -> 5.26.1-6ubuntu0.3 > ( perl ) Broken pkg-config:i386 Depends on dpkg-dev [ i386 ] < none -> 1.19.0.5ubuntu2.3 > ( utils ) Broken build-essential:i386 Depends on dpkg-dev [ i386 ] < none -> 1.19.0.5ubuntu2.3 > ( utils ) (>= 1.17.11) Broken libdbus-1-dev:i386 Depends on pkg-config [ i386 ] < none -> 0.29.1-0ubuntu2 > ( devel ) Broken libglib2.0-dev:i386 Depends on libpcre3-dev [ i386 ] < none -> 2:8.39-9 > ( libdevel ) (>= 1:8.31) Broken python-dbus-dev:i386 Depends on libdbus-1-dev [ i386 ] < none -> 1.12.2-1ubuntu1.1 > ( libdevel ) (>= 1.6) Broken libharfbuzz-dev:i386 Depends on libglib2.0-dev [ i386 ] < none -> 2.56.4-0ubuntu0.18.04.6 > ( libdevel ) (>= 2.19.1) Broken libmagickwand-6.q16-2:i386 Depends on libmagickcore-6.q16-2 [ i386 ] < 8:6.8.9.9-7ubuntu5.15 > ( libs ) (>= 8:6.8.9.9) Broken libmagickcore-6.q16-2-extra:i386 Depends on libmagickcore-6.q16-2 [ i386 ] < 8:6.8.9.9-7ubuntu5.15 > ( libs ) (>= 8:6.8.9.9) Broken python3-zope.hookable:i386 Depends on python3 [ i386 ] < 3.5.1-3 -> 3.6.7-1~18.04 > ( python ) (< 3.6) Broken libicu-le-hb-dev:i386 Depends on libharfbuzz-dev [ i386 ] < none -> 1.7.2-1ubuntu1 > ( libdevel ) Broken libicu-dev:i386 Depends on libicu-le-hb-dev [ i386 ] < none -> 1.0.3+git161113-4 > ( libdevel ) Broken icu-devtools:i386 Breaks on libicu-dev [ i386 ] < 55.1-7ubuntu0.5 -> 60.2-3ubuntu3.1 > ( libdevel ) (< 60.2-3ubuntu3.1) Broken libicu-dev:i386 Depends on libicu-le-hb-dev [ i386 ] < none -> 1.0.3+git161113-4 > ( libdevel ) Broken icu-devtools:i386 Breaks on libicu-dev [ i386 ] < 55.1-7ubuntu0.5 -> 60.2-3ubuntu3.1 > ( libdevel ) (< 60.2-3ubuntu3.1) Broken libicu-dev:i386 Depends on libicu-le-hb-dev [ i386 ] < none -> 1.0.3+git161113-4 > ( libdevel ) Broken icu-devtools:i386 Breaks on libicu-dev [ i386 ] < 55.1-7ubuntu0.5 -> 60.2-3ubuntu3.1 > ( libdevel ) (< 60.2-3ubuntu3.1) Broken libicu-dev:i386 Depends on libicu-le-hb-dev [ i386 ] < none -> 1.0.3+git161113-4 > ( libdevel ) Broken icu-devtools:i386 Breaks on libicu-dev [ i386 ] < 55.1-7ubuntu0.5 -> 60.2-3ubuntu3.1 > ( libdevel ) (< 60.2-3ubuntu3.1) Broken libicu-dev:i386 Depends on libicu-le-hb-dev [ i386 ] < none -> 1.0.3+git161113-4 > ( libdevel ) Broken icu-devtools:i386 Breaks on libicu-dev [ i386 ] < 55.1-7ubuntu0.5 -> 60.2-3ubuntu3.1 > ( libdevel ) (< 60.2-3ubuntu3.1) Broken libicu-dev:i386 Depends on libicu-le-hb-dev [ i386 ] < none -> 1.0.3+git161113-4 > ( libdevel ) Broken icu-devtools:i386 Breaks on libicu-dev [ i386 ] < 55.1-7ubuntu0.5 -> 60.2-3ubuntu3.1 > ( libdevel ) (< 60.2-3ubuntu3.1) Broken libicu-dev:i386 Depends on libicu-le-hb-dev [ i386 ] < none -> 1.0.3+git161113-4 > ( libdevel ) Broken icu-devtools:i386 Breaks on libicu-dev [ i386 ] < 55.1-7ubuntu0.5 -> 60.2-3ubuntu3.1 > ( libdevel ) (< 60.2-3ubuntu3.1) Broken libicu-dev:i386 Depends on libicu-le-hb-dev [ i386 ] < none -> 1.0.3+git161113-4 > ( libdevel )
What i should do with it? Please help
There are many ways to solve this issue , if you want to upgrade but can't:
Way 1
Step 1 : open Software & Updates.
Step 2 : change Download from to Main Server
Step 3 : open Terminal (ctlr + alt + t) then sudo apt-get update , then sudo apt-get upgrade
Way 2 Remove PPA
Step 2 : go to Other Software tab and choose the desire PPA from the list. Afterwards click on Remove to remove it.
OR
You can remove it using terminal : sudo apt-add-repository -r PPA_Name/ppa
Way 3 :
Read This
also try to use this commands , may it help: sudo apt clean , sudo apt autoclean , sudo apt autoremove.
AEM
  • 1,156
  • 14
  • 19
