I am running Ubuntu 18.04 LTS on a Dell Inspiron 15 7559. I had been having issues with putting my computer to sleep by closing the lid (I think it's related to my GPU). Last night I closed it inadvertently and got errors such as
acpi INT3400:00: Unsupported event [0x86]
psmouse serio1: elantech: failed to write register 0x07 with value 0x01
psmouse serio1: elantech: failed to initialise registers.
psmouse serio1: elantech: failed to put touchpad back into absolute mode
NVRM: Xid(PCI:0000:02:00): 79, GPU has fallen off the bus.
I didn't pay much attention to it as it's happened in the past. I restarted manually, Ubuntu proposed some updates that I downloaded and applied.
Next I Firefox crashed any time I tried to download anything. killall firefox didn't do anything and I was forced to restart every time.
Now I notice that nautilus crashes, I can't open it directly. Running strace nautilus finishes with
munmap(0x7ff4c1973000, 46084)           = 0
munmap(0x7ff4c197f000, 1)               = 0
access("/run", F_OK)                    = 0
stat("/run", {st_mode=S_IFDIR|0755, st_size=940, ...}) = 0
access("/run/user", F_OK)               = 0
stat("/run/user", {st_mode=S_IFDIR|0755, st_size=80, ...}) = 0
access("/run/user/1000", F_OK)          = 0
stat("/run/user/1000", {st_mode=S_IFDIR|0700, st_size=320, ...}) = 0
access("/run/user/1000/dconf", F_OK)    = 0
stat("/run/user/1000/dconf", {st_mode=S_IFDIR|0700, st_size=60, ...}) = 0
openat(AT_FDCWD, "/run/user/1000/dconf/user", O_RDWR|O_CREAT, 0600) = 16
pwrite64(16, "\0", 1, 1)                = 1
mmap(NULL, 1, PROT_READ, MAP_SHARED, 16, 0) = ?
+++ killed by SIGBUS (core dumped) +++
Bus error (core dumped)
In the last lines.
I ran sudo nautilus and it works, although now I am aware I shouldn't have done it.
I have no clue what is going on and can't find similar cases online, so any help would be appreciated.
First of all try reinstalling faulty apps by:
sudo apt purge nautilus && rm -fr ~/.local/share/nautilus
sudo apt purge firefox && sudo apt autoremove
sudo apt clean && sudo apt update && sudo apt install nautilus firefox
Reinstall your GPU drivers
But you could also check your disk for bad sectors:
sudo badblocks -sv /dev/sdXY  > bad-blocks-result
And fix them, if required:
sudo fsck -t ext4 -l bad-blocks-result /dev/sdXY
And to kill an application use killall -9 firefox. It will terminate it forcefully. It is if your application could not be stopped just by killall firefox command.
Gryu
  • 8,002
  • 37
  • 53
