I could need some help with a oneline script im building. The script should give me a list of services, which are running on the current system. I wanted to realize this with systemctl.
The current oneliner looks like this:
systemctl list-units --type service | grep -f /etc/update-motd.d/service.list
However this command always creates a blank line between the services which are listed
  smbd.service                       loaded active running Samba SMB Daemon
  uuidd.service                      loaded active running Daemon for generating UUIDs
  virtlogd.service                   loaded active running Virtual machine log manager
  zabbix-agent.service               loaded active running Zabbix Agent
I would like to remove the empty spaces. After some google research ive found some solutions with tr (like 'tr -d ""' or 'tr -s ""'), but this doesnt seem to work. Ive even tried some solutions with grep or sed but none of them helped me wih this.
edit: following solutions I tried without success: | grep "." | sed '/^$/d | grep "\S"
Some help would be great! Thanks
You can try something like this: systemctl list-units --type service | grep -f /etc/update-motd.d/service.list | grep -v ^$ This should remove any emtpy lines
BulletBob
  • 1,830
Using tr to squeeze newlines:
$ systemctl list-units --type service | \
  grep -f <(tr < /etc/update-motd.d/service.list -s \\n)
What you are seeing are not empty lines - they're long trailing sequences of space characters that appear to be part of the systemctl tabular output:
$ systemctl list-units --type service | grep bluetooth | xxd
00000000: 626c 7565 746f 6f74 682e 7365 7276 6963  bluetooth.servic
00000010: 6520 2020 2020 2020 2020 2020 2020 2020  e
00000020: 2020 2020 2020 2020 2020 2020 2020 2020
00000030: 2020 2020 2020 2020 2020 2020 2020 2020
00000040: 2020 2020 2020 2020 2020 2020 2020 2020
00000050: 2020 2020 2020 2020 2020 6c6f 6164 6564            loaded
00000060: 2061 6374 6976 6520 7275 6e6e 696e 6720   active running
00000070: 426c 7565 746f 6f74 6820 7365 7276 6963  Bluetooth servic
00000080: 6520 2020 2020 2020 2020 2020 2020 2020  e
00000090: 2020 2020 2020 2020 2020 2020 2020 2020
000000a0: 2020 2020 2020 2020 2020 2020 2020 2020
000000b0: 2020 2020 2020 2020 2020 2020 200a                    .
They appear as empty lines because of wrapping by the terminal.
You can remove them with tr, for example by squeezing horizontal whitespace:
$ systemctl list-units --type service |  tr -s '[:blank:]' | grep -f service.list
bluetooth.service loaded active running Bluetooth service
cron.service loaded active running Regular background program processing daemon
polkit.service loaded active running Authorization Manager
Another option, which preserves the tabular format better, would be to remove only trailing spaces:
$ systemctl list-units --type service | sed 's/ *$//' | grep -f service.list
There should be a way to stop systemctl from trying to format the output (or at least to be responsive to the COLUMNS environment variable), but I can't find it.
steeldriver
  • 142,475
