I have installed ranger file manager and rxvt-unicode terminal, and I want ranger to display previews of images in the terminal. I have also installed w3m, but I can't get images to preview. I think this is an issue for w3m, because when I load webpages with w3m, no images appear.
edit: w3m will now display images when i load webpages and images, but ranger does not preview....
I am running Ubuntu 18.04.4 LTS x86_64 I think I need to get urxvt with pixbuf support, but I have no idea how to get that. I have tried searching to find out how to get urxvt with pixbuf support, but only results for arch etc. is available it seem like.
fdfdsd
  • 103
Update 22 April 2025
The 2022 solution works just fine, but since it is easier to work with supported projects, there is currently a drop-in replacement for ueberzug called ueberzugpp. It can be installed as described here for xUbuntu 24.10 (please click the link for other versions):
echo 'deb http://download.opensuse.org/repositories/home:/justkidding/xUbuntu_24.10/ /' | sudo tee /etc/apt/sources.list.d/home:justkidding.list
curl -fsSL https://download.opensuse.org/repositories/home:justkidding/xUbuntu_24.10/Release.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/home_justkidding.gpg > /dev/null
sudo apt update
sudo apt install ueberzugpp
and the configs stay the same as on the original answer
Update 1 December 2022
This solution is not suggested anymore as it is quite difficult to install ueberzug now that the project is not under active development.
But…
If one insists on using this method, you can build ueberzug manually with:
sudo apt install libxext-dev libx11-dev -y
git clone --depth 1 --branch 18.1.9 https://github.com/seebye/ueberzug.git
cd ueberzug
python3 setup.py install
Original Answer
TL;DR
  1. On the default Ubuntu terminal, I installed ueberzug with: pip3 install ueberzug
  2. On rangers configurations at ~/.config/ranger/rc.conf I added( or edited already existing) these two lines :
set preview_images true
set preview_images_method  ueberzug
  1. Worked like a charm (and it will work on any other terminal as well)
My other trials:
I just had the same experience as you and I couldn't make it work, but I have a few notes on your trial and a pretty easy alternative that actually worked
First thing first w3m package of Ubuntu doesn't contain image preview so you need to explicitly type sudo apt install w3m-img then you need to locate it on the path at a place like /usr/lib/w3m/w3mimagedisplay and add it to your path. Though this installation of w3mimagedisplay seems broken to me, you might have better luck. Also, kitty as suggested by the other answer worked for me, though I didn't have time to change my default terminal as I have a lot of configurations on it. So I count this solution more "lightweight" as it just needs one python script to run. Even though kitty is a handy terminal and many people might prefer it.
10
Ranger does not have image previewing enabled by default. You need to enable it in its configuration file.
First, in case you do not already have a user-specific config file, create one by copying the default config file:
mkdir -pv ~/.config/ranger/
cp -vi /usr/share/doc/ranger/config/rc.conf ~/.config/ranger/rc.conf
Then open ~/.config/ranger/rc.conf using your favorite text editor.
To enable image previews, find the preview_images option and change it to true. i.e. the line would read:
Then, find the option preview_images_method, and set it according to your terminal to one of the values enumerated and explained in the comment block preceding it. In your case, it's urxvt. So the line should read:
set preview_images_method urxvt
After that, quit ranger and start it again for the new configuration to take effect.
If all fails, I personally use it with the Kitty terminal and it works. If you want to try it out, first install Kitty, change the aforementioned preview_images_method option to kitty, then launch kitty and start ranger in it.
I have Ubuntu 22.04 and I managed to use image preview with ranger and foot terminal.
First I installed sixel:
sudo apt install libsixel-bin libsixel-dev libsixel1
Sixel requires a recent ranger, so I removed the package and I downloaded and installed the latest from source:
sudo apt remove ranger
git clone https://github.com/ranger/ranger.git
cd ranger
sudo make install
If you have not already done, copy the default ranger config:
cp -vni /usr/local/share/doc/ranger/config/rc.conf ~/.config/ranger/rc.conf
I enabled image preview as some other answers correctly stated in ~/.config/ranger/rc.conf:
Then I configured it to preview with sixel
set preview_images_method sixel
Now start ranger and it will correctly render image previews.
