Here is what it gives me:
root@tal-HP-Notebook:~# apt install nodejs
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 linux-image-generic : Depends: linux-image-4.4.0-176-generic but it is not going to be installed or
                                linux-image-unsigned-4.4.0-176-generic but it is not going to be installed
 linux-modules-extra-4.4.0-176-generic : Depends: linux-image-4.4.0-176-generic but it is not going to be installed or
 nodejs : Depends: libuv1 (>= 1.6.1) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Do you know what to do?
When i try apt-get -f install, it gives me the following:
root@tal-HP-Notebook:~# apt-get -f install
Correcting dependencies... Done
The following additional packages will be installed:
Suggested packages:
  fdutils linux-doc-4.4.0 | linux-source-4.4.0 linux-tools
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 252 not upgraded.
7 not fully installed or removed.
Need to get 6,937 kB of archives.
After this operation, 7,238 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://il.archive.ubuntu.com/ubuntu xenial-updates/main amd64 linux-image-4.4.0-176-generic amd64 4.4.0-176.206 [6,937 kB]
Fetched 6,937 kB in 7s (892 kB/s)
(Reading database ... 590241 files and directories currently installed.)
Preparing to unpack .../linux-image-4.4.0-176-generic_4.4.0-176.206_amd64.deb ...
Unpacking linux-image-4.4.0-176-generic (4.4.0-176.206) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-176-generic_4.4.0-176.206_amd64.deb (--unpack):
 cannot copy extracted data for './boot/vmlinuz-4.4.0-176-generic' to '/boot/vmlinuz-4.4.0-176-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
        dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
I think the whole problem is that i don't have enough disk space on the boot partition (it only has 500mb and is currently full).
I tried a few things, including trying to purge/erase some older kernel versions, but to no avail.
For some reason when i start the computer i have to press del in order to boot the computer with some older kernel version, it got messed up (and i didn't touch the version which was active).
I hope you'll be able to help me..
slava
  • 4,085
