System was working fine before I removed git using sudo apt --purge autoremove git
Now, every time I try to install some package or even run sudo apt upgrade I get the following error
sudo apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up emacs25 (25.2+1-6) ...
/var/lib/dpkg/info/emacs25.postinst: 35: /var/lib/dpkg/info/emacs25.postinst: /usr/lib/emacsen-common/emacs-install: not found
dpkg: error processing package emacs25 (--configure):
installed emacs25 package post-installation script subprocess returned error exit status 127
dpkg: dependency problems prevent configuration of emacs:
emacs depends on emacs25 | emacs25-lucid | emacs25-nox; however:
Package emacs25 is not configured yet.
Package emacs25-lucid is not installed.
Package emacs25-nox is not installed.
dpkg: error processing package emacs (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of git-el:
git-el depends on emacs | emacsen; however:
Package emacs is not configured yet.
Package emacsen is not installed.
Package emacs25 which provides emacsen is not configured yet.
dpkg: error processing package git-el (--configure):
dpkg: dependency problems prevent configuration of git-all:
git-all depends on git-el; however:
Package git-el is not configured yet.
dpkg: error processing package git-all (--configure):
emacs25
emacs
git-el
git-all
emacs 26.3 has been built from source and is working fine. Please help me solve this problem.
TIA!
