I am using the following OS version:
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.4 LTS
Release: 18.04
Codename: bionic
When I run sudo apt-get update, I get the following message:
Ign:2 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:3 http://dl.google.com/linux/chrome/deb stable Release
Ign:1 https://dl.bintray.com/etcher/debian stable InRelease
Hit:7 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Get:6 https://dl.bintray.com/etcher/debian stable Release [3,674 B]
Hit:8 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu bionic InRelease
Get:5 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Get:10 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Hit:11 https://release.memsql.com/production/debian memsql InRelease
Hit:12 http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu bionic InRelease
Hit:4 https://packagecloud.io/github/git-lfs/ubuntu bionic InRelease
Ign:14 http://us.archive.ubuntu.com/ubuntu bionic/universe arm64 Packages
Ign:15 http://us.archive.ubuntu.com/ubuntu bionic/main arm64 Packages
Get:16 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [652 kB]
Get:17 http://security.ubuntu.com/ubuntu bionic-security/universe arm64 Packages [580 kB]
Ign:17 http://security.ubuntu.com/ubuntu bionic-security/universe arm64 Packages
Ign:28 http://security.ubuntu.com/ubuntu bionic-security/main arm64 Packages
Err:14 http://us.archive.ubuntu.com/ubuntu bionic/universe arm64 Packages
404 Not Found [IP: 91.189.91.38 80]
Ign:29 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe arm64 Packages
Get:30 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe i386 Packages [1,012 kB]
Get:31 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [1,060 kB]
Get:32 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe Translation-en [328 kB]
Get:33 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 DEP-11 Metadata [273 kB]
Get:34 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 48x48 Icons [204 kB]
Get:35 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 64x64 Icons [476 kB]
Err:17 http://security.ubuntu.com/ubuntu bionic-security/universe arm64 Packages
404 Not Found [IP: 91.189.91.39 80]
Get:36 http://us.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [892 kB]
Get:37 http://us.archive.ubuntu.com/ubuntu bionic-updates/main arm64 Packages [641 kB]
Ign:37 http://us.archive.ubuntu.com/ubuntu bionic-updates/main arm64 Packages
Err:29 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe arm64 Packages
Fetched 181 kB in 2s (89.4 kB/s)
Reading package lists... Done
N: Skipping acquire of configured file 'etcher/binary-arm64/Packages' as repository 'https://deb.etcher.io stable InRelease' doesn't support architecture 'arm64'
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/bionic/universe/binary-arm64/Packages 404 Not Found [IP: 91.189.91.38 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/bionic-security/universe/binary-arm64/Packages 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/bionic-updates/universe/binary-arm64/Packages 404 Not Found [IP: 91.189.91.38 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
When I try to run the command to install gtk sudo apt-get install -y libgtk2.0-dev I get the following message:
Building dependency tree
The following additional packages will be installed:
autoconf automake autopoint debhelper dh-autoreconf dh-strip-nondeterminism gir1.2-gtk-2.0 gir1.2-harfbuzz-0.0 icu-devtools libarchive-cpio-perl libatk1.0-dev libcairo-script-interpreter2 libcairo2-dev
libfile-stripnondeterminism-perl libfontconfig1-dev libfreetype6-dev libgdk-pixbuf2.0-dev libglib2.0-dev libglib2.0-dev-bin libgraphite2-dev libharfbuzz-dev libharfbuzz-gobject0 libice-dev libicu-dev
libicu-le-hb-dev libicu-le-hb0 libiculx60 libmail-sendmail-perl libpango1.0-dev libpcre16-3 libpcre3-dev libpcre32-3 libpcrecpp0v5 libpixman-1-dev libpng-dev libpng-tools libpthread-stubs0-dev libsigsegv2
libsm-dev libsys-hostname-long-perl libx11-dev libx11-doc libxau-dev libxcb-render0-dev libxcb-shm0-dev libxcb1-dev libxcomposite-dev libxcursor-dev libxdamage-dev libxdmcp-dev libxext-dev libxfixes-dev
libxft-dev libxi-dev libxinerama-dev libxrandr-dev libxrender-dev m4 pkg-config po-debconf x11proto-composite-dev x11proto-core-dev x11proto-damage-dev x11proto-dev x11proto-fixes-dev x11proto-input-dev
x11proto-randr-dev x11proto-xext-dev x11proto-xinerama-dev xorg-sgml-doctools xtrans-dev zlib1g-dev
Suggested packages:
autoconf-archive gnu-standards autoconf-doc dh-make dwz libcairo2-doc libglib2.0-doc libgraphite2-utils libgtk2.0-doc libice-doc icu-doc libpango1.0-doc libsm-doc libxcb-doc libxext-doc m4-doc
libmail-box-perl
The following NEW packages will be installed:
libfile-stripnondeterminism-perl libfontconfig1-dev libfreetype6-dev libgdk-pixbuf2.0-dev libglib2.0-dev libglib2.0-dev-bin libgraphite2-dev libgtk2.0-dev libharfbuzz-dev libharfbuzz-gobject0 libice-dev
libicu-dev libicu-le-hb-dev libicu-le-hb0 libiculx60 libmail-sendmail-perl libpango1.0-dev libpcre16-3 libpcre3-dev libpcre32-3 libpcrecpp0v5 libpixman-1-dev libpng-dev libpng-tools libpthread-stubs0-dev
libsigsegv2 libsm-dev libsys-hostname-long-perl libx11-dev libx11-doc libxau-dev libxcb-render0-dev libxcb-shm0-dev libxcb1-dev libxcomposite-dev libxcursor-dev libxdamage-dev libxdmcp-dev libxext-dev
libxfixes-dev libxft-dev libxi-dev libxinerama-dev libxrandr-dev libxrender-dev m4 pkg-config po-debconf x11proto-composite-dev x11proto-core-dev x11proto-damage-dev x11proto-dev x11proto-fixes-dev
x11proto-input-dev x11proto-randr-dev x11proto-xext-dev x11proto-xinerama-dev xorg-sgml-doctools xtrans-dev zlib1g-dev
0 upgraded, 73 newly installed, 0 to remove and 4 not upgraded.
Need to get 1,487 kB/26.0 MB of archives.
After this operation, 120 MB of additional disk space will be used.
Ign:1 http://security.ubuntu.com/ubuntu bionic-security/main amd64 libglib2.0-dev-bin amd64 2.56.4-0ubuntu0.18.04.4
Ign:2 http://security.ubuntu.com/ubuntu bionic-security/main amd64 libglib2.0-dev amd64 2.56.4-0ubuntu0.18.04.4
Err:1 http://us.archive.ubuntu.com/ubuntu bionic-security/main amd64 libglib2.0-dev-bin amd64 2.56.4-0ubuntu0.18.04.4
404 Not Found [IP: 91.189.88.142 80]
Err:2 http://us.archive.ubuntu.com/ubuntu bionic-security/main amd64 libglib2.0-dev amd64 2.56.4-0ubuntu0.18.04.4
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/g/glib2.0/libglib2.0-dev-bin_2.56.4-0ubuntu0.18.04.4_amd64.deb 404 Not Found [IP: 91.189.88.142 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/g/glib2.0/libglib2.0-dev_2.56.4-0ubuntu0.18.04.4_amd64.deb 404 Not Found [IP: 91.189.88.142 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
For reference, this is my /etc/apt/sources.list file (I recently reset it to see if this is the issue)
deb http://us.archive.ubuntu.com/ubuntu/ bionic universe main
deb http://security.ubuntu.com/ubuntu/ bionic-security universe main
deb http://us.archive.ubuntu.com/ubuntu/ bionic-updates universe main
Any idea what the issue may be. This is very frustrating.
