19
I have been using VMWare on Windows for a long time. But after a long wait, I moved to VirtualBox on Ubuntu 11.10. I installed Ubuntu, 32 Bit, installed all available updates and installed Virtual Box. When I try to create a new Windows installation inside VirtualBox, I got the following error messages.
VirtualBox - Error
Failed to open a session for the virtual machine Windows XP.
The virtual machine '**Windows XP**' has terminated unexpectedly during startup with exit code 1.
Details
Result Code:
NS_ERROR_FAILURE (0x80004005)
Component:
Machine
Interface:
IMachine {5eaa9319-62fc-4b0a-843c-0cb1940f8a91}
2nd error dialogue
Virtualbox - Error in suplibOsinit
Kernal driver not installed (rc--1908)
Please install the virtualbox-dkmbs package and execute 'modprobe vboxdrv' as root.
  • I have already tried reinstalling VirtualBox.
  • Google result seem to indicate the the problem happens due to Kernel updates.
Is there anyway I can get this working? I need this for malware analysis and if VirtualBox is going to crash on me all the time, then I won't be able to use Ubuntu for work.
Output to dpkg -l | grep virtual
 server
rc  virtualbox                             4.1.2-dfsg-1ubuntu1
x86 virtualization solution - base binaries
rc  virtualbox-qt                          4.1.2-dfsg-1ubuntu1
x86 virtualization solution - Qt based user interface
cute 'modprobe vboxdrv' as root.<p>
Braiam
  • 69,112
Sunil J
  • 315
13 Answers13
17
Wierdly, for me it worked by closing VirtualBox and then running
sudo modprobe vboxdrv
from the terminal and then restarting VirtualBox
JomanJi
  • 311
I had the same problem and solved it by
  1. Purging Virtualbox:
    sudo apt-get purge virtualbox virtualbox-dkms virtualbox-ose-qt virtualbox-qt
  2. I then reinstalled;
    sudo apt-get install virtualbox virtualbox-dkms virtualbox-ose virtualbox
    and noticed:
    dependency problems prevent configuration of virtualbox-ose:
    virtualbox-ose depends on virtualbox; however:
    Package virtualbox is not configured yet.
    Package virtualbox-4.0 which provides virtualbox is not installed.
  3. so I tried installing virtualbox-4.0;
    sudo apt-get install virtualbox-4.0
    That worked and pulled in the correct VirtualBox DKMS kernel modules.
  4. I then had to download and install the correct version of the extension pack Oracle_VM_VirtualBox_Extension_Pack-4.0.16-75491.vbox-extpack.
That worked, and I now have a fully functioning Virtualbox instance.
Try to uninstall VirtualBox from the command line:
If it succesfully uninstalled reinstall it:
sudo apt-get install virtualbox virtualbox-dkms virtualbox-ose-qt virtualbox-qt
Carefully check if the command completes succesfully.
jippie
  • 5,733
I was getting NS_ERROR_FAILURE (0x80004005) whenever I try to start the VM in Debian 9 unstable. None of the solution worked including re-building kernel modules, starting in headless mode etc.
Then I tried to install extension pack and it failed due to /opt being not owned by the root! I fixed the ownership of /opt and then the pack installed successfully and also virtualbox starts! weird!
Anwar
  • 77,855
I had almost the same error:
Then a second window appeared saying I had to run this command:
sudo /etc/init.d/vboxdrv setup
When I Issued that command the following error came out:
$ sudo /etc/init.d/vboxdrv setup
 * Stopping VirtualBox kernel modules                                                             [ OK ]
 * Uninstalling old VirtualBox DKMS kernel modules        [ OK ]
 * Trying to register the VirtualBox kernel modules using DKMS
Error! Your kernel headers for kernel 2.6.38-16-generic-pae cannot be found at
/lib/modules/2.6.38-16-generic-pae/build or /lib/modules/2.6.38-16-generic-pae/source.
Failed, trying without DKMS
Recompiling VirtualBox kernel modules        Look at /var/log/vbox-install.log to find out what went wrong
Solution
Install the appropriated linux-headers for your O.S. version. In my case was:
sudo apt-get install linux-headers-2.6.38-16-generic-pae
Ensure all VirtualBox windows are closed.
Peachy
  • 7,235
  • 40
  • 47
Alexis
I tried this : To fix this, run the following, as directed by the prompt:
If successful, the result will read Starting VirtualBox kernel modules [ OK ] and it's OK now
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
I had this issue but fortunately I solved it not from comand line but from GUI... open your home directory ~/VirtualBox VMs
open your hard disk image file
open name of your virtual machine.vbox
Your virtual box should run normally from here and that should fix your problem( if you had the same issue I had , the problem shown up when I had all data in my VirtualBox.xml in the .VirtualBox directory was gone!!!)
Another suggestion: If the previous one didn't work for you ...
go to .Virtualbox in you home directory
type the following (cp VirtualBox.xml-prev VirtualBox.xml)
I think this should do it for you too...
Good luck...
Seth
  • 59,332
Solution :
sudo apt-get install virtualbox-dkms
sudo apt-get install linux-headers-generic
sudo /etc/init.d/virtualbox start
 * Starting VirtualBox kernel modules
execute virtualbox :
/usr/bin/virtualbox or virtualbox
guntbert
  • 13,475
Haikel
This is due to extension pack's different version than other VB packages.
Fix
1) Removing extension pack - sudo apt-get remove virtualbox-extension-pack
2) Disable USB 2 support from VM settings
It will works ! If you want to use extension pack , reinstall the correct version. You can download it from here.
Dumindu
Run /sbin/vboxconfig as superuser. You may have to wait after some error messages before it completes the command.
If successful, the result will read * Starting VirtualBox kernel modules [ OK ]
If it fails, the reason should be logged in /var/log/vbox-install.log but it always seems to be because headers for the current (host) kernel are missing: Your kernel headers for kernel 3.5.0-22-generic cannot be found so install them then try again:
sudo apt-get install linux-headers-$(uname -r) ## e.g. 3.5.0-22-generic
Note: You will need to do this after every kernel upgrade unless package-maintainers find a solution.
Alastair
  • 211
-2
Something that seems to not be covered is kernel source. You need the kernel headers for your current kernel installed or it will fail to build the modules needed, resulting in this error.
Routh
This is so easy. I had the same problem and I was wondered how easy to solve this is. Make sure to close VirtualBox first, completly. Then issue the following command:
sudo vboxreload
That's it! I found this out by typing "vbox" and hitting TAB twice on arch linux. This should also work on Ubuntu and any other distribution.
guntbert
  • 13,475
Julian
