14
I'm looking for a tool that will take diff / debdiff output (and more specifically, the output of this script) and display the result of the comparison in a highly readable, graphical way. Any pointers would be appreciated.
Ideally, it would be the GTK+, FOSS equivalent of MDR.
Meld, Diffuse and similar software are not fit for this purpose, since they're intended to work standalone, and don't take input from stdin.
mgunes
  • 9,910
6 Answers6
Kompare can do this (and is the best GUI diff-viewer IMO):
./whatchanged package_name | kompare -
Note the '-' given as the input file argument. Most *nix programs have this interface to accept piped input, so you can probably use whichever one you like.
scottl
  • 2,588
If you only have a console, colordiff is a quite good solution.
To install it, run this command sudo apt-get install colordiff in a terminal
Anwar
  • 77,855
Mnementh
  • 307
I would use this simple script to use meld (or any of the other existing tools), that way you get a little bit of flexibility:
#!/bin/bash
TMPDIR=`mktemp -d`
DIFF_FILE=`mktemp`
TARGET='./'
cat /proc/$$/fd/0 > $DIFF_FILE
cd $TARGET
rsync -apvz --delete --stats --compress --progress $TARGET $TMPDIR
patch -R -p0 -d $TMPDIR < $DIFF_FILE
meld $TARGET $TMPDIR
Tested with meld and the output from bzr diff, so copied this into /usr/bin and chmod 755 and I did this:
bzr diff | meld-diff
The results show as expected.
I like using vim's internal syntax highlighting as a pager, so that I can view colorized diffs. For example, putting this in your .bashrc:
sudo apt-get install vim
alias vless='vim -u /usr/share/vim/vimcurrent/macros/less.vim'
(And then re-source your .bashrc with . ~/.bashrc.) Then you can run vless as your pager:
vless /path/to/your.diff
It's not graphical, but it is at least highlighted.
Kees Cook
  • 17,823
Although a KDE application it can be installed without TOO many dependencies, kdiff is an awesome diff editing / merge tool.
I know you are not ask for a diff tool integrated to a editor, but I'm sure you can avoid context switch (from editor to terminal, and back to editor) after learn a bit about what your editor can provides. Both, emacs and vim comes with diff tools.
  • For emacs case, you will use Ediff Mode (instaled by default). Look at this wiki page or consulting the official manual
  • Using emacs is simple, just type Alt + x and type ediff.
  • You can use ediff to browser difference beetween branches and revisions of your repository (bzr, git, svn, etc).
crncosta
  • 2,869
