Recently, I've been backing up a lot of my data, and I noticed that I can save files as .gz or .tar.gz, or .7z and .tar.7z, etcetera. What are the differences between the normal one and the .tar.* variant? Which one of them is adviced when making backups?
- 7,735
If you come from a Windows background, you may be familiar with the zip and rar formats. These are archives of multiple files compressed together.
In Unix and Unix-like systems (like Ubuntu), archiving and compression are separate.
tarputs multiple files into a single (tar) file.gzipcompresses one file (only).
So, to get a compressed archive, you combine the two, first use tar or pax to get all files into a single file (archive.tar), then gzip it (archive.tar.gz).
If you have only one file, you need to compress (notes.txt): there's no need for tar, so you just do gzip notes.txt which will result in notes.txt.gz. There are other types of compression, such as compress, bzip2 and xz which work in the same manner as gzip (apart from using different types of compression of course).
- 47,279
It depends on what you are looking for... Compression or archiving?
When I talk about archiving, I mean preserving permissions, directory structure, etc...
Compression may ignore most of that and just get your files in a smaller packages.
To preserve file permissions, use tar:
tar cpvf backup.tar folder
The p flag will save file permissions. Use the z flag for gzip compression or the j flag for bzip compression.
tar czpvf backup.tar.gz folder #backup.tgz is acceptable as well
tar cjpvf backup.tar.bz2 folder #backup.tbz2 works too
If you want to have a tar file you can "update" package the tar using the P flag:
tar cpPvf backup.tar folder
Then to update, replace 'c' with 'u' and when unpacking, you can use 'k' to preserve files that already exist.
tar upPvf backup.tar folder #updating a tar file
tar xpPkvf backup.tar #extracting a tar with permissions(p) and not extracting(k) files that exist on disk already
The P flag saves files with full paths, so - /home/username vs home/username (notice the leading forward slash).
7z compression offers greater compression, but does not preserve file ownership, permissions, etc. Rzip is another compression utility that offers comparable compression with 7z as well.
I guess a backup.tar.7z file is just a tar file (with permissions) compressed by a 7z file, though I wouldn't be surprised if little compression occurred because 7z may not be able to dump the file metadata. It's 7z's ability to exclude the file metadata that it can offer great compression (amongst other things of course).
Compression depends entirely on data type as well. Some files don't compress well because they may already be compressed with some other means (ie, .mp3, .jpg, .tiff/with lzma, .rpm, etc).
- 1,772
gzip or bzip2 doesn't know about file system - file name, directory, or tree structure. It just compresses input stream, then output result. Even gzip or bzip2 can't archive directories on their own, that is why it is usually combined with tar.
tar(archiver) - just archive file structure. gzip,bzip2(compressor) - just compress input.
I think this strategy came from 'do one thing well' Unix philosophy. Tar works well? Leave it as is. Need more compression ratio than gzip? Here is bzip2 or 7zip.
its different styles of compression , tar by itself is simply archived(little to no compression). tar.gz is a tar archive but the contents are compressed by gzip(moderate compression) hence the .gz and tar.7z is compressed using 7zip (usually super high compression)
when backing up I would recommend tar.7z as it has the highest compression rate saving you space but uses an extra program (7zip). .tar.gz will be larger files and do the same job, you could also use bzip (.tar.bz/bz2) although i'm not sure if that would suit you better as I use gzip or 7zip
- 869
typically, *.tar files are just tar files created by tar program, *.gz programs are created by gzip, *.tar.gz (sometime also *.tgz) are gziped tar files, and *.7z are created by 7zip.
However, in Linux/Unix, one can name a file pretty much anyway he wants, so it is completely at the discretion of the creator of the files.
- 910
Tar (Tape Archiver) has traditionally been used as a container in Unix/Linux to package files for movement. It packages the file structure and maintains file attributes, but it doesn't compress the files.
Compression programs compress the file to make it smaller, but they may not handle multiple files, and/or they may not handle the file attributes neccesssary for Linux. Since tar already exists and is well-supported, there's no reason for archiving programs to duplicate this functionality, which is platform-specific (re, different for Windows and Linux). Also, different compression programs may perform differently on different types of files, so having a choice of more than one is desirable.
- 18,944
Other answers have explained the difference between compression and archiving well.
7z is an archiver, which means it knows about the internal directory structure, file names, etc. without having to decompress everything. However, there are some limitations. I quote from man 7z on my Ubuntu system:
Backup and limitations
DO NOT USE the 7-zip format for backup purpose on Linux/Unix because :
- 7-zip does not store the owner/group of the file.
On Linux/Unix, in order to backup directories you must use tar :
- to backup a directory : tar cf - directory | 7za a -si directory.tar.7z
- to restore your backup : 7za x -so directory.tar.7z | tar xf -
If you want to send files and directories (not the owner of file) to others Unix/MacOS/Windows users, you can use the 7-zip format.
example : 7za a directory.7z directory
Do not use "-r" because this flag does not do what you think.
Do not use directory/* because of ".*" files (example : "directory/*" does not match "directory/.profile")
There you have it. One can use tar inside 7z (resulting in directory.tar.7z) to make sure you have preserved all the special Linux goodies. However, 7z will only know about the one tar file inside, and the entire tar file will have to be unpacked and read to discover what lies inside. Therefore, for a bunch of regular files, and where ownership doesn't matter, just use 7z directly.
Also, if a tar file (or a compressed tar.anything file) is damaged, you will only be able to recover your data up to the point of injury. With an archive like 7z (not using tar inside) your chances of recovering more files are better.
PS: 7z can also create solid archives, which result in better compression, but comes with the same limitations as using tar inside any compressor. Source: https://en.wikipedia.org/wiki/Solid_compression
- 346
