I've tried pgrep redshift, pgrep -f redshift, ps -ax | grep redshift, ps -elf | grep redshift, ps -ax -u root -U root | g redshift, systemctl | grep redshift all without finding the process, yet the icon is sitting in the System Tray and I can adjust the settings via the command line. It is listed in my Autostart GUI in Kubuntu as redshift-gtk.
I'm trying to set the temp to a specific level, because clicking the icon steps are to large of dimming, using this: https://askubuntu.com/a/1077895/795299, and then restart redshift.
Requested in comment:
/usr
/usr/bin
/usr/bin/redshift-gtk
/usr/lib
/usr/lib/python3
/usr/lib/python3/dist-packages
/usr/lib/python3/dist-packages/redshift_gtk
/usr/lib/python3/dist-packages/redshift_gtk/__init__.py
/usr/lib/python3/dist-packages/redshift_gtk/controller.py
/usr/lib/python3/dist-packages/redshift_gtk/defs.py
/usr/lib/python3/dist-packages/redshift_gtk/statusicon.py
/usr/lib/python3/dist-packages/redshift_gtk/utils.py
/usr/lib/systemd
/usr/lib/systemd/user
/usr/lib/systemd/user/redshift-gtk.service
/usr/share
/usr/share/appdata
/usr/share/appdata/redshift-gtk.appdata.xml
/usr/share/applications
/usr/share/applications/redshift-gtk.desktop
/usr/share/doc
/usr/share/doc/redshift-gtk
/usr/share/doc/redshift-gtk/copyright
/usr/share/icons
/usr/share/icons/hicolor
/usr/share/icons/hicolor/scalable
/usr/share/icons/hicolor/scalable/apps
/usr/share/icons/hicolor/scalable/apps/redshift-status-off.svg
/usr/share/icons/hicolor/scalable/apps/redshift-status-on.svg
/usr/share/icons/hicolor/scalable/apps/redshift.svg
/usr/share/icons/ubuntu-mono-dark
/usr/share/icons/ubuntu-mono-dark/scalable
/usr/share/icons/ubuntu-mono-dark/scalable/apps
/usr/share/icons/ubuntu-mono-dark/scalable/apps/redshift-status-off.svg
/usr/share/icons/ubuntu-mono-dark/scalable/apps/redshift-status-on.svg
/usr/share/icons/ubuntu-mono-light
/usr/share/icons/ubuntu-mono-light/scalable
/usr/share/icons/ubuntu-mono-light/scalable/apps
/usr/share/icons/ubuntu-mono-light/scalable/apps/redshift-status-off.svg
/usr/share/icons/ubuntu-mono-light/scalable/apps/redshift-status-on.svg
/usr/share/man
/usr/share/man/man1
/usr/share/menu
/usr/share/menu/redshift-gtk
/usr/bin/gtk-redshift
/usr/share/doc/redshift-gtk/NEWS.Debian.gz
/usr/share/doc/redshift-gtk/README.gz
/usr/share/doc/redshift-gtk/changelog.Debian.gz
/usr/share/man/man1/redshift-gtk.1.gz
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii redshift 1.12-2 amd64 Adjusts the color temperature of your screen
ii redshift-gtk 1.12-2 all Adjusts the color temperature of your screen with GTK+ integration
un redshift-plasmoid <none> <none> (no description available)
