I'm new to Linux and I had to install Maya AutoDesk for a homework, I tried like for two hours, but I couldn't make it work. I decided to install it later, but I think I've messed something up. I tried to install neofetch a few days later with this command.
foo@bar:~$ sudo apt install neofetch
But it came with a problem
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libpng12-dev : Depends: libpng12-0 (= 1.2.54-1ubuntu1) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
So I tried to use,
sudo apt --fix-broken install
But this appear
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
libappindicator1 libc++1 libc++1-9 libc++abi1-9 libdbusmenu-gtk4
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libpng12-0
The following NEW packages will be installed:
libpng12-0
0 upgraded, 1 newly installed, 0 to remove and 12 not upgraded.
1 not fully installed or removed.
Need to get 0 B/116 kB of archives.
After this operation, 285 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 302707 files and directories currently installed.)
Preparing to unpack .../libpng12-0_1.2.54-1ubuntu1_amd64.deb ...
Unpacking libpng12-0:amd64 (1.2.54-1ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/libpng12-0_1.2.54-1ubuntu1_amd64.deb (--unpack):
unable to install new version of '/lib/x86_64-linux-gnu/libpng12.so.0': No such file or directory
No apport report written because the error message indicates an issue on the local system
I don't know what to do, I would really appreciate any help. It's also my first post so any feedback it's welcome.
I also tried to do
foo@bar:~$ sudo apt install --reinstall libpng12-0
But this apeared,
libpng12-0
file or directory
al system
