I am told I am missing the dependency: libcublas-dev . I am suggested to use sudo apt --fix-broken install. However, when I run this I receive an error about the paste subprocess being killed by signal (Broken pipe).
I have also tried directly installing the dependency and also receive a broken pipe error.
Here is the output I receive. I have read some similar topics about overwriting a .deb file but did not have any luck with them.
~$ sudo apt --fix-broken install Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done The following packages were automatically installed and are no longer required: fonts-liberation2 fonts-opensymbol gir1.2-geocodeglib-1.0 gir1.2-gst-plugins-base-1.0 gir1.2-gstreamer-1.0 gir1.2-gudev-1.0 gir1.2-udisks-2.0 grilo-plugins-0.3-base gstreamer1.0-gtk3 libatomic1:i386 libboost-date-time1.65.1 libboost-filesystem1.65.1 libboost-iostreams1.65.1 libboost-locale1.65.1 libbsd0:i386 libcdr-0.1-1 libclucene-contribs1v5 libclucene-core1v5 libcmis-0.5-5v5 libcolamd2 libdazzle-1.0-0 libdrm-amdgpu1:i386 libdrm-intel1:i386 libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libe-book-0.1-1 libedataserverui-1.2-2 libedit2:i386 libelf1:i386 libeot0 libepubgen-0.1-1 libetonyek-0.1-1 libevent-2.1-6 libexiv2-14 libexpat1:i386 libffi6:i386 libfreerdp-client2-2 libfreerdp2-2 libgc1c2 libgee-0.8-2 libgexiv2-2 libgl1:i386 libgl1-mesa-dri:i386 libglapi-mesa:i386 libglvnd0:i386 libglx-mesa0:i386 libglx0:i386 libgom-1.0-0 libgpgmepp6 libgpod-common libgpod4 liblangtag-common liblangtag1 liblirc-client0 libllvm9:i386 liblua5.3-0 libmediaart-2.0-0 libmspub-0.1-1 libnvidia-common-430 libnvidia-common-435 libodfgen-0.1-1 libpciaccess0:i386 libqqwing2v5 libraw16 librevenge-0.0-0 libsensors4:i386 libsgutils2-2 libssh-4 libstdc++6:i386 libsuitesparseconfig5 libvncclient1 libwinpr2-2 libx11-6:i386 libx11-xcb1:i386 libxapian30 libxau6:i386 libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386 libxcb-sync1:i386 libxcb1:i386 libxdamage1:i386 libxdmcp6:i386 libxext6:i386 libxfixes3:i386 libxmlsec1 libxmlsec1-nss libxshmfence1:i386 libxxf86vm1:i386 linux-headers-4.15.0-74 linux-headers-4.15.0-74-generic linux-headers-5.0.0-23 linux-headers-5.0.0-23-generic linux-image-4.15.0-74-generic linux-image-5.0.0-23-generic linux-modules-4.15.0-74-generic linux-modules-5.0.0-23-generic linux-modules-extra-4.15.0-74-generic linux-modules-extra-5.0.0-23-generic lp-solve media-player-info python3-mako python3-markupsafe syslinux syslinux-common syslinux-legacy usb-creator-common Use 'sudo apt autoremove' to remove them. The following additional packages will be installed: libcublas-dev The following NEW packages will be installed: libcublas-dev 0 upgraded, 1 newly installed, 0 to remove and 150 not upgraded. 7 not fully installed or removed. Need to get 0 B/42.3 MB of archives. After this operation, 114 MB of additional disk space will be used. Do you want to continue? [Y/n] y (Reading database ... 288268 files and directories currently installed.) Preparing to unpack .../libcublas-dev_10.2.2.89-1_amd64.deb ... Unpacking libcublas-dev (10.2.2.89-1) ... dpkg: error processing archive /var/cache/apt/archives/libcublas-dev_10.2.2.89-1_amd64.deb (--unpack): trying to overwrite '/usr/include/nvblas.h', which is also in package nvidia-cuda-dev 9.1.85-3ubuntu1 dpkg-deb: error: paste subprocess was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/libcublas-dev_10.2.2.89-1_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
Ubuntu 18.04
