I have been using Ubuntu 18.04 for about a month now on a Dual Boot system. I've had WiFi issues in the past, but nothing that couldn't be fixed by a reboot. However, recently I have not been able to connect to WiFi at all.
On typing lspci, I get the following:
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 08)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #9 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point LPC Controller/eSPI Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (4) I219-V (rev 21)
02:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
04:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
05:00.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
06:00.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
06:01.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
06:02.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
06:04.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
07:00.0 System peripheral: Intel Corporation JHL6540 Thunderbolt 3 NHI (C step) [Alpine Ridge 4C 2016] (rev 02)
3b:00.0 USB controller: Intel Corporation JHL6540 Thunderbolt 3 USB Controller (C step) [Alpine Ridge 4C 2016] (rev 02)
As you can see, the computer uses Intel WiFi drivers. Sometimes, they don't show up at all with this command.
I've tried all the steps on this answer without much success: No WiFi Adaptor found in Lenovo X1 Carbon Generation 7
I just installed Ubuntu 19.10, hoping the problem would be solved, but that didn't help either. I am currently on 19.10
I am able to connect through USB tethering though, and the WiFi has worked for 5-10 minutes these past few days.
Also, WiFi works just find when I boot into Windows.
Any help would be greatly appreciated!
Edit 1: Here is the output of sudo modprobe iwlwifi && dmesg | grep iwl
The output is too long, so here are the opening and ending lines:
[ 2.780409] iwlwifi 0000:02:00.0: Found debug destination: EXTERNAL_DRAM
[ 2.780412] iwlwifi 0000:02:00.0: Found debug configuration: 0
[ 2.780859] iwlwifi 0000:02:00.0: loaded firmware version 36.77d01142.0 op_mode iwlmvm
[ 2.929533] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 2.941530] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ 2.941898] iwlwifi 0000:02:00.0: Allocated 0x00400000 bytes for firmware monitor.
[ 2.995866] iwlwifi 0000:02:00.0: base HW address: 18:1d:ea:c4:e7:f3
[ 3.077166] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 3.121398] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[ 4.922362] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ 5.056426] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ 5.124598] iwlwifi 0000:02:00.0: FW already configured (0) - re-configuring
[ 11.996082] iwlwifi 0000:02:00.0: Error sending TIME_EVENT_CMD: time out after 2000ms.
[ 11.996085] iwlwifi 0000:02:00.0: Current CMD queue read_ptr 67 write_ptr 68
[ 12.013670] WARNING: CPU: 7 PID: 304 at drivers/net/wireless/intel/iwlwifi/pcie/trans.c:2015 iwl_trans_pcie_grab_nic_access+0x1f9/0x230 [iwlwifi]
[ 12.013671] Modules linked in: snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic bnep x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel nls_iso8859_1 kvm irqbypass snd_soc_skl snd_soc_hdac_hda snd_hda_ext_core joydev snd_soc_skl_ipc snd_seq_midi snd_soc_sst_ipc snd_seq_midi_event snd_soc_sst_dsp crct10dif_pclmul crc32_pclmul i915 snd_soc_acpi_intel_match snd_soc_acpi snd_soc_core mei_hdcp snd_compress ac97_bus snd_pcm_dmaengine iwlmvm intel_rapl_msr ghash_clmulni_intel snd_hda_intel snd_rawmidi snd_intel_nhlt mac80211 aesni_intel snd_hda_codec uvcvideo btusb libarc4 rmi_smbus btrtl rmi_core thinkpad_acpi snd_hda_core snd_hwdep aes_x86_64 crypto_simd videobuf2_vmalloc nvram drm_kms_helper btbcm cryptd input_leds videobuf2_memops glue_helper btintel videobuf2_v4l2 intel_cstate videobuf2_common serio_raw snd_pcm wmi_bmof bluetooth intel_wmi_thunderbolt snd_seq ledtrig_audio intel_rapl_perf iwlwifi videodev mc drm snd_seq_device processor_thermal_device snd_timer
[ 12.013735] RIP: 0010:iwl_trans_pcie_grab_nic_access+0x1f9/0x230 [iwlwifi]
[ 12.013749] iwl_write_prph+0x3e/0x90 [iwlwifi]
[ 12.013753] iwl_force_nmi+0x53/0x60 [iwlwifi]
[ 12.013758] iwl_trans_pcie_sync_nmi+0x1f1/0x260 [iwlwifi]
[ 12.013763] iwl_pcie_send_hcmd_sync+0x3ca/0x4b0 [iwlwifi]
[ 12.013770] iwl_trans_pcie_send_hcmd+0x34/0xe0 [iwlwifi]
[ 12.013775] iwl_trans_send_cmd+0x5d/0xc0 [iwlwifi]
[ 12.013783] iwl_mvm_send_cmd+0x34/0x90 [iwlmvm]
[ 12.013788] iwl_mvm_send_cmd_pdu+0x51/0x70 [iwlmvm]
[ 12.013795] iwl_mvm_remove_time_event+0xc9/0xe0 [iwlmvm]
[ 12.013800] iwl_mvm_stop_session_protection+0x5a/0x90 [iwlmvm]
[ 12.013805] iwl_mvm_protect_session+0x127/0x2a0 [iwlmvm]
[ 12.013811] ? iwl_mvm_ref_sync+0x34/0x130 [iwlmvm]
[ 12.013816] iwl_mvm_mac_mgd_prepare_tx+0x64/0x90 [iwlmvm]
[ 12.013820] ? iwl_mvm_mac_mgd_prepare_tx+0x64/0x90 [iwlmvm]
[ 12.013887] iwlwifi 0000:02:00.0: iwlwifi transaction failed, dumping registers
Ending:
[ 17.049253] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[ 17.049568] iwlwifi 0000:02:00.0: HW_REV=0xFFFFFFFF, PCI issues?
[ 17.100389] iwlwifi: probe of 0000:02:00.0 failed with error -5
Edit 2: On entering dmesg | grep 02:00:
[ 0.639695] pci 0000:02:00.0: [8086:24fd] type 00 class 0x028000
[ 0.639803] pci 0000:02:00.0: reg 0x10: [mem 0xee200000-0xee201fff 64bit]
[ 0.640435] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 12.013889] iwlwifi 0000:02:00.0: iwlwifi device config registers:
[ 12.014080] iwlwifi 0000:02:00.0: 00000000: 24fd8086 00100000 02800078 00000000 00000004 00000000 00000000 00000000
[ 12.014081] iwlwifi 0000:02:00.0: 00000020: 00000000 00000000 00000000 00108086 00000000 000000c8 00000000 00000100
[ 12.014083] iwlwifi 0000:02:00.0: 00000040: 00020010 10008ec0 001b0c10 0045e811 10110000 00000000 00000000 00000000
[ 12.014084] iwlwifi 0000:02:00.0: 00000060: 00000000 00080812 00000005 00000000 00010001 00000000 00000000 00000000
[ 12.014086] iwlwifi 0000:02:00.0: 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 12.014087] iwlwifi 0000:02:00.0: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 12.014088] iwlwifi 0000:02:00.0: 000000c0: 00000000 00000000 c823d001 0d000000 00804005 00000000 00000000 00000000
[ 12.014089] iwlwifi 0000:02:00.0: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 12.014091] iwlwifi 0000:02:00.0: 00000100: 14010001 00100000 00000000 00462031 00003001 00002000 00000014 40000001
[ 12.014092] iwlwifi 0000:02:00.0: 00000120: 0000000f ee200460 00000000 00000000 00000000 00000000 00000000 00000000
[ 12.014094] iwlwifi 0000:02:00.0: 00000140: 14c10003 ffc4e7f3 181deaff 15410018 00000000 0001001e 00481e1f 00000000
[ 12.014095] iwlwifi 0000:02:00.0: iwlwifi device memory mapped registers:
[ 12.014123] iwlwifi 0000:02:00.0: 00000000: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[ 12.014124] iwlwifi 0000:02:00.0: 00000020: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[ 12.014127] iwlwifi 0000:02:00.0: iwlwifi device AER capability structure:
[ 12.014151] iwlwifi 0000:02:00.0: 00000000: 14010001 00100000 00000000 00462031 00003001 00002000 00000014 40000001
[ 12.014152] iwlwifi 0000:02:00.0: 00000020: 0000000f ee200460 00000000
[ 12.014153] iwlwifi 0000:02:00.0: iwlwifi parent port (0000:00:1c.0) config registers:
[ 12.014252] iwlwifi 0000:02:00.0: iwlwifi root port (0000:00:1c.0) AER cap structure:
[ 12.032234] iwlwifi 0000:02:00.0: HW error, resetting before reading
[ 12.056226] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[ 12.056228] iwlwifi 0000:02:00.0: Status: 0x00000080, count: -1850087776
[ 12.056252] iwlwifi 0000:02:00.0: Loaded firmware version: 36.77d01142.0
[ 12.056254] iwlwifi 0000:02:00.0: 0xFFFFFFFF | ADVANCED_SYSASSERT
[ 12.056255] iwlwifi 0000:02:00.0: 0x0000048B | trm_hw_status0
[ 12.056255] iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
[ 12.056256] iwlwifi 0000:02:00.0: 0xC0902620 | branchlink2
[ 12.056262] iwlwifi 0000:02:00.0: 0xFFFFFFFF | interruptlink1
[ 12.056265] iwlwifi 0000:02:00.0: 0x0000082F | interruptlink2
[ 12.056267] iwlwifi 0000:02:00.0: 0x00000000 | data1
[ 12.056270] iwlwifi 0000:02:00.0: 0x00000002 | data2
[ 12.056272] iwlwifi 0000:02:00.0: 0x00000000 | data3
[ 12.056274] iwlwifi 0000:02:00.0: 0x00000246 | beacon time
[ 12.056276] iwlwifi 0000:02:00.0: 0x00000000 | tsf low
[ 12.056277] iwlwifi 0000:02:00.0: 0x00000246 | tsf hi
[ 12.056278] iwlwifi 0000:02:00.0: 0x00000000 | time gp1
[ 12.056279] iwlwifi 0000:02:00.0: 0xFFFFFF13 | time gp2
[ 12.056281] iwlwifi 0000:02:00.0: 0xFFFFFFFF | uCode revision type
[ 12.056282] iwlwifi 0000:02:00.0: 0x90AA1A45 | uCode version major
[ 12.056283] iwlwifi 0000:02:00.0: 0xFFFFFFFF | uCode version minor
[ 12.056285] iwlwifi 0000:02:00.0: 0x00000010 | hw version
[ 12.056286] iwlwifi 0000:02:00.0: 0x00000000 | board version
[ 12.056287] iwlwifi 0000:02:00.0: 0xFFFF9D1A | hcmd
[ 12.056288] iwlwifi 0000:02:00.0: 0x00000018 | isr0
[ 12.056290] iwlwifi 0000:02:00.0: 0x00000000 | isr1
[ 12.056291] iwlwifi 0000:02:00.0: 0x00000246 | isr2
[ 12.056293] iwlwifi 0000:02:00.0: 0x00000000 | isr3
[ 12.056295] iwlwifi 0000:02:00.0: 0xC092B51A | isr4
[ 12.056296] iwlwifi 0000:02:00.0: 0xFFFFFFFF | last cmd Id
[ 12.056298] iwlwifi 0000:02:00.0: 0x00573978 | wait_event
[ 12.056299] iwlwifi 0000:02:00.0: 0xFFFF9D1A | l2p_control
[ 12.056301] iwlwifi 0000:02:00.0: 0x00000028 | l2p_duration
[ 12.056302] iwlwifi 0000:02:00.0: 0xFFFF8C42 | l2p_mhvalid
[ 12.056304] iwlwifi 0000:02:00.0: 0x005739F8 | l2p_addr_match
[ 12.056305] iwlwifi 0000:02:00.0: 0xFFFF9D1A | lmpm_pmg_sel
[ 12.056307] iwlwifi 0000:02:00.0: 0x00573998 | timestamp
[ 12.056309] iwlwifi 0000:02:00.0: 0xFFFF9D1A | flow_handler
[ 12.074962] iwlwifi 0000:02:00.0: 0xC092B51A | ADVANCED_SYSASSERT
[ 12.074964] iwlwifi 0000:02:00.0: 0xFFFFFFFF | umac branchlink1
[ 12.074965] iwlwifi 0000:02:00.0: 0x00573978 | umac branchlink2
[ 12.074966] iwlwifi 0000:02:00.0: 0xFFFF9D1A | umac interruptlink1
[ 12.074967] iwlwifi 0000:02:00.0: 0x00000028 | umac interruptlink2
[ 12.074968] iwlwifi 0000:02:00.0: 0xFFFF8C42 | umac data1
[ 12.074968] iwlwifi 0000:02:00.0: 0x005739F8 | umac data2
[ 12.074969] iwlwifi 0000:02:00.0: 0xFFFF9D1A | umac data3
[ 12.074970] iwlwifi 0000:02:00.0: 0x00573998 | umac major
[ 12.074971] iwlwifi 0000:02:00.0: 0xFFFF9D1A | umac minor
[ 12.074972] iwlwifi 0000:02:00.0: 0xAEBB2A00 | frame pointer
[ 12.074972] iwlwifi 0000:02:00.0: 0x85429601 | stack pointer
[ 12.074973] iwlwifi 0000:02:00.0: 0xCB0D9E28 | last host cmd
[ 12.074974] iwlwifi 0000:02:00.0: 0xFFFF8C42 | isr status reg
[ 12.093246] iwlwifi 0000:02:00.0: Collecting data: trigger 2 fired.
[ 12.093538] iwlwifi 0000:02:00.0: Couldn't send TIME_EVENT_CMD: -5
[ 14.789902] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ 14.896234] iwlwifi 0000:02:00.0: Could not load the [0] uCode section
[ 14.896258] iwlwifi 0000:02:00.0: Failed to start INIT ucode: -5
[ 14.896259] iwlwifi 0000:02:00.0: Failed to run INIT ucode: -5
[ 14.896260] iwlwifi 0000:02:00.0: Failed to start RT ucode: -5
[ 14.896262] iwlwifi 0000:02:00.0: Collecting data: trigger 16 fired.
[ 14.931951] iwlwifi 0000:02:00.0: HW error, resetting before reading
[ 14.955891] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[ 14.955912] iwlwifi 0000:02:00.0: Status: 0x00000010, count: 7
[ 14.955913] iwlwifi 0000:02:00.0: Loaded firmware version: 36.77d01142.0
[ 14.955914] iwlwifi 0000:02:00.0: 0x00000000 | ADVANCED_SYSASSERT
[ 14.955915] iwlwifi 0000:02:00.0: 0x31122B54 | trm_hw_status0
[ 14.955915] iwlwifi 0000:02:00.0: 0x0000000D | trm_hw_status1
[ 14.955916] iwlwifi 0000:02:00.0: 0xC0902620 | branchlink2
[ 14.955917] iwlwifi 0000:02:00.0: 0xFFFFFFFF | interruptlink1
[ 14.955918] iwlwifi 0000:02:00.0: 0x00000007 | interruptlink2
[ 14.955918] iwlwifi 0000:02:00.0: 0x00000000 | data1
[ 14.955919] iwlwifi 0000:02:00.0: 0x00000002 | data2
[ 14.955920] iwlwifi 0000:02:00.0: 0x00000000 | data3
[ 14.955920] iwlwifi 0000:02:00.0: 0x00000246 | beacon time
[ 14.955921] iwlwifi 0000:02:00.0: 0x00000000 | tsf low
[ 14.955922] iwlwifi 0000:02:00.0: 0x00000246 | tsf hi
[ 14.955922] iwlwifi 0000:02:00.0: 0x00000000 | time gp1
[ 14.955923] iwlwifi 0000:02:00.0: 0xFFFFFF13 | time gp2
[ 14.955924] iwlwifi 0000:02:00.0: 0xFFFFFFFF | uCode revision type
[ 14.955924] iwlwifi 0000:02:00.0: 0x90AA1A45 | uCode version major
[ 14.955925] iwlwifi 0000:02:00.0: 0xFFFFFFFF | uCode version minor
[ 14.955926] iwlwifi 0000:02:00.0: 0x00000010 | hw version
[ 14.955927] iwlwifi 0000:02:00.0: 0x00000000 | board version
[ 14.955927] iwlwifi 0000:02:00.0: 0xFFFF9D1A | hcmd
[ 14.955928] iwlwifi 0000:02:00.0: 0x00000018 | isr0
[ 14.955929] iwlwifi 0000:02:00.0: 0x00000000 | isr1
[ 14.955929] iwlwifi 0000:02:00.0: 0x00000246 | isr2
[ 14.955930] iwlwifi 0000:02:00.0: 0x00000000 | isr3
[ 14.955931] iwlwifi 0000:02:00.0: 0x00413BD0 | isr4
[ 14.955931] iwlwifi 0000:02:00.0: 0xFFFF9D1A | last cmd Id
[ 14.955932] iwlwifi 0000:02:00.0: 0xC090517F | wait_event
[ 14.955933] iwlwifi 0000:02:00.0: 0xFFFFFFFF | l2p_control
[ 14.955933] iwlwifi 0000:02:00.0: 0xCAFC0018 | l2p_duration
[ 14.955934] iwlwifi 0000:02:00.0: 0xFFFF8C42 | l2p_mhvalid
[ 14.955935] iwlwifi 0000:02:00.0: 0xCAFC0018 | l2p_addr_match
[ 14.955936] iwlwifi 0000:02:00.0: 0xFFFF8C42 | lmpm_pmg_sel
[ 14.955936] iwlwifi 0000:02:00.0: 0x00A01C30 | timestamp
[ 14.955937] iwlwifi 0000:02:00.0: 0x00000000 | flow_handler
[ 14.973783] iwlwifi 0000:02:00.0: 0x00413BD0 | ADVANCED_SYSASSERT
[ 14.973821] iwlwifi 0000:02:00.0: 0xFFFF9D1A | umac branchlink1
[ 14.973822] iwlwifi 0000:02:00.0: 0xC090517F | umac branchlink2
[ 14.973823] iwlwifi 0000:02:00.0: 0xFFFFFFFF | umac interruptlink1
[ 14.973824] iwlwifi 0000:02:00.0: 0xCAFC0018 | umac interruptlink2
[ 14.973825] iwlwifi 0000:02:00.0: 0xFFFF8C42 | umac data1
[ 14.973827] iwlwifi 0000:02:00.0: 0xCAFC0018 | umac data2
[ 14.973828] iwlwifi 0000:02:00.0: 0xFFFF8C42 | umac data3
[ 14.973829] iwlwifi 0000:02:00.0: 0x00A01C30 | umac major
[ 14.973831] iwlwifi 0000:02:00.0: 0x00000000 | umac minor
[ 14.973833] iwlwifi 0000:02:00.0: 0xFC59A700 | frame pointer
[ 14.973834] iwlwifi 0000:02:00.0: 0x73C73D65 | stack pointer
[ 14.973835] iwlwifi 0000:02:00.0: 0xCB0D9E28 | last host cmd
[ 14.973836] iwlwifi 0000:02:00.0: 0xFFFF8C42 | isr status reg
[ 14.991671] iwlwifi 0000:02:00.0: Firmware error during reconfiguration - reprobe!
[ 14.991697] iwlwifi 0000:02:00.0: Firmware not running - cannot dump error
[ 16.836170] iwlwifi 0000:02:00.0: iwl_trans_wait_tx_queues_empty bad state = 0
