I am using Navicat for MySQL on Ubuntu 18.04.4 LTS with the native Gnome UI. Prior versions of Navicat used Wine, but this version (15) provides an AppImage file which I have been launching from the terminal. Once launched, it ties up that terminal process until I exit Navicat. This annoys me.
I've found several walkthroughs that pertain to the Wine version on Unity, but nothing for running the AppImage on Gnome. Is there any way I can create a shortcut on the launcher bar (or wherever) in Gnome so I don't have to launch the process from a terminal window?
AJ.
  • 391
You could do it using appimaged:
  • Download trial version of navicat15 from here
  • chmod +x ~/Downloads/navicat15-mysql-en.AppImage
  • mkdir ~/bin
  • cp ~/Downloads/navicat15-mysql-en.AppImage ~/bin
  • Download appimaged:
    wget "https://github.com/AppImage/appimaged/releases/download/continuous/appimaged-x86_64.AppImage"
  • chmod a+x appimaged-x86_64.AppImage
  • ./appimaged-x86_64.AppImage --install
  • export PATH=$PATH:/home/user/.local/bin - optional, if your echo $PATH does not contain /home/user/.local/bin directory, where appimaged binary is copied. Could be added in ~/.bashrc
  • Run it by appimaged -v - this command will register .AppImage file found in ~/bin directory
  • After some time check Applications menu and find out Navicat 15 for MySQL there.
  • Interrupt appimaged -v command execution by Ctrl+C.
Tested on Ubuntu 19.10 and Lubuntu 18.04.
Gryu
  • 8,002
  • 37
  • 53
